Question about Dell Dimension 4700 PC Desktop
Single Beep on boot... repeats after 2-3 seconds, no video
Elite K7SEM MB, AMD Sempron, 1GB mem
Did a software reboot on the system, and now all I get is a single beep as though POST has completed. It looks like the disks are being hit, but I don't get any video signal. After about 3 seconds, I get the beep again.
Have replaced memory, removed other cards, tried unplugging the disks and replaced the video card.
HELP!!!!!!
    Scholar:
  • 92 Answers
This is a tough one. On some system bioses one beep means a problem with the RAM. On most it means a succesful POST. Are you getting any video? Have you tried booting to a boot disk? Have you tried a new hard drive? Have you tried to clear the CMOS? Good Luck!
Posted on Jun 27, 2009
  • 44 Answers
Try unplugging everything. and reconnect. of that fails disconnect mains power and take the cmos battery out. leave for 5 mins and put battery in and connect mains and try that. other than that the only other thing you can do is pull out your cpu and jput back in just remember to renew the thermal paste on the cpu
Installing new motherboard, processor, mem, and video adapter. Powers on but no post.
If the beep is a very high pitched tone, turn off the computer. Your CPU is overheating. The thermal paste may not be spread correctly on the CPU or the heat sink isn't properly installed.
Otherwise, it's probably a memory error. This machine takes 2 GB of memory as 2 single GB memory sticks. Try booting the machine with only one DIMM installed. Try each stick individually before getting replacement memory.
I hope this helps.
Jan 27, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Getting a single beep upon startup, no video signal going to monitor.
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 14, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD ATHLON THAT JUST CONTINUES A LONG REPEATING BEEP AT BOOT AND AM NOT RECIEVING SIGNAL TO MONITOR. IS IT MEMORY OR VIDEO . CAN'T GET A CLEAR TOPIC FOR THE...
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
Nov 23, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
I have AMD Sempron 140 on ASUS M2N68-AM SE2 motherboard, Strontium 1GB PC800 DDR2 RAM. But in system properties, the RAM is showing as 768 MB instead of 1024 MB (WinXP 32 bit). The dealer is saying the RAM...
Yes the dealer is correct that the 256 MB of your RAM is allocated to the video card of this computer since the unit has a built in NVIDIA GeForce 7025 Shared video memory (UMA)that uses 256 MB of your RAM , so if you like to maximize the use of your RAM you need to install a expansion video card.
Sep 07, 2010 | Computers & Internet
Im using a emachines T3646 computer,only pwrled and 1syst fan wrk
Yes. Got RAM? The heatsink fan? How about a video card, and all the 12V (4 to 6 pin) connectors? All plugged in suitably?
May 02, 2010 | eMachines T3646 Refurbished AMD Desktop...
When installing ram i hear a single long repeated beep im trying to install 1gb DDR ram sticks two of them
either you have the wrong ram! for the gateway or your trying to add too much to it gateways only will hold so much before thet reject the ram the machine goes into a over draft in the onboard memory
Jan 19, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
On boot up computer keeps restarting with a single beep motherboard model- k7sem elite group
the symptom you're describing my be a classic Gigabyte response to bad memory. First of all, go into bios, make sure your RAM voltage and timings are set correctly. If they are correct, you likely have a bad stick of RAM. Remove one stick, test the system, if the problem persists, swap sticks and try again
also try this if it continues Right click My Computer click Properties -> Advanced -> Startup and Recovery. Uncheck Automatically restart. It should give you a blue screen that may give you some indication as to the cause.
Feb 20, 2009 | EliteGroup K7SEM Motherboard
YOUR NFORCE3-A POST/BOOT BEEP
i need this driver for my computer please
May 19, 2008 | EliteGroup nForce3-A Motherboard
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Thanks
Iqbal
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
Dell Dimension 4700 PC Desktop Logo
564 people viewed this question
Alun Cox
