Question about Proscan 19LA20Q LCD TV
HOW MANY VOLTS IS THE POWER CORD FOR THIS TV - Proscan 19LA20Q LCD TV
Use any step down transformer that is input 110ac to output 12vdc 5 watt- canadian tire in canada sells one for the food coolers used in vechicles(KOOLATRON) -about $35.00 -you would have to splice in a connector in the end to fit the tv- I have been using one for the last two months and it works fine
Posted on Aug 20, 2009
  • 578 Answers
110 ac
Posted on Jun 27, 2009
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
My power cord from the tv to the 12 volt receptacle in my truck has broken. Do you know where I can get that power cord for my 19" Naxa TV/DVD 12 volt combo TV?
Tries websites like Amazon.com,Partstore.com,Ebay.com to buy a replacement.U talking about a car adapter charger wright?U tried Walmart,Target or Radio Shack yet?Tried those places first.
Aug 07, 2011 | Televison & Video
When i turn tv on the power button shows its on but no pic or sound
the power supply of your TV must be check.the power output of the power supply suppose to be 12 volts for audio,24 volts for the backlight lamp and 5volts for the main CPU. use a multimeter to measure the voltage In the case of your TV it seems only 5 volts is present that is why you have a power indicator lit....open the back cover of your TV and measure the power supply.power supply board is where the power cord is connected...
Apr 19, 2011 | Sansui HDLCD3200 TV
Craig High Definition LCD TV (15.6 in) power cord
The power source is a 12 volt transformer so you can use a standard universal power supply. A 12 volt DC Power Cord with Auto Cigarette Lighter type Adapter will work in an auto.
Nov 03, 2009 | Televison & Video
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Dc cord
i just found a power cord took me like 3 months but heres the web site LCDPAYLESS.com make sure its a 6 volt charger though and the guy is nice, i paid almost 80 dollars and it was here within a week any more questions j hit me up.
Apr 21, 2009 | iLO 2600 Television
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Supersonic FC2200 TV Power Cord Usage
need a power cord for FC2200 supersonic hdtv. where can i find one
Jun 30, 2008 | Supersonic FC2025 9 in. TV/DVD Combo
Proscan 19LA20Q LCD TV Logo
308 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
