Whirlpool washer model lsr9434pq0 no hot water and stops between cycles dead
  • Anonymous Mar 20, 2014
    I am trying to find out how oldthis washer is
    President:
  • 1,136 Answers
Hi, Remove the inlet hoses and see if the screen inside the inlet valve is plugged. When the washer is suppose to be filling, do you hear the inlet valve humming when it is set on hot water cycle?
As far as the stopping in cycle, Does it wash and then stop before it goes into spin or will it stop in the wash cycle?
I am just trying to get clarification please
Posted on Jun 27, 2009
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Dec 25, 2009 | Whirlpool Washing Machines
I have a model LA5550XTW0 washing machine and have a timer that stops at the spin cycle and cold water does not flow into the tube when it is set to cold water only. Can I just replace the timer or do I...
Assuming you have hot and cold water supply to the back of the washer, the most probable cause of no cold water would be a bad valve. As to the no spin complaint if it only happens in 1 cycle it may be the timer but you don't say if the machine is dead or if you manually advance the timer will the washer spin. Also you don't say whether the washer drains out or not.
your spin problem could be caused by a bad lid switch, pressure switch or timer, Then there is also the possibly that the spin problem is mechanical rather than electrical
Dec 16, 2009 | Whirlpool Washing Machines
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
