Question about Garden
Hi On a model 130202 type 0135-07 a friend pulled off the rewind starter housing and turned it upside down. The two are not easily going back together - any tips for reassembly?
  • 126 Answers
SOURCE: Reassemble pram after washing
Graco Children's Products Inc.
Product Instructions
LINK: http://www.gracobaby.com/customerservice/instructions.aspx
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Posted on Apr 28, 2008
  • 32 Answers
SOURCE: pull cord won't rewind
the shaft isnt attached right.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Posted on Aug 23, 2009
Testimonial: "Sounds good! I'll check it out and let you know. Thanks!"
SOURCE: I need to rewind the spring and starter pull cord.
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Posted on Aug 28, 2009
SOURCE: cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Posted on May 23, 2010
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Recoil starter assembly
If you can post the engine make, model and serial number I can get a diagram for you. They are usually stamped in the engine housing. Start by removing bolts to remove cover and check spring. If spring is good you should be able to rewind. You will need to cut rope by handle and pull rope up between spindle and inner housing, rewind rope in direction of pull. Let it rewind while holding tip of rope. When satisfied with tension, push end of rope back through hole in cover and reattach handle. This can be tricky. I am thinking of posting a video of this procedure. Let me know if you have more question's.Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Dec 03, 2013 | Ariens Garden
Broken starter cord to re thread
I'm going to assume you have a new rope. If you look at the rewind pulley (plastic disc) there should be a hole where the original rope went through. Run the rope through this hole and then through the hole in the starter housing itself. At the other end of the rope near the pulley, tie a knot at the end of the rope and pull it through the housing until your new knot is up against the hole in pulley. Next put the rope through the starter handle and tie another knot. Now you should have a rope with a knot on both ends with the handle near one, and the pulley on the other end. Now if you look at the pulley on the outer edges, you will see a notch in it. Hold the rope into that notch and spin the pulley in a clockwise rotation for about four turns. Don't let go of pulley because there will be tension on the spring. Hold pulley with your thumb while pulling rope out of housing on the handle side until taught. Hold rope outside of housing and release pulley. Now slowly release rope on handle side of housing an let it slide back around pulley. When tension is released and if there is still rope hanging out of starter housing, repeat the above steps but instead of going four turns around with rope in notch, only go one at a time until the handle is all the way back to housing. It's important not to go too many times with your wrap around because it will cause spring to be too tight which may cause breakage in the future....Just go far enough to let handle touch the housing and you should be good to go.
This would be much easier to show in a video than in type. I hope this helps.
Sep 21, 2012 | Stihl Chainsaw Rewind Starter Spring 024...
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
The pull cord is stuck, can't be pulled to start
This solution applies to the Sears model 358.797200, which also appears to the FL1500LE marketed under the Craftsman name, and may apply to other, similar, blowers. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment. (The binding may easily be misdiagnosed as a seized up engine.) The binding can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Oct 25, 2009 | Garden
How to recoil starter cord on MTD yard machine
Since you didn't tell us what brand of engine it is or a model number of the mower I can only guess that it is a Briggs & Stratton because that is the one that most folks have trouble figuring out.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Oct 09, 2009 | Garden
Broken starter cord on a mountfield M6 lawnmower - how do you re attach the cord
This unit is supposed to have a Briggs & Stratton engine on it so:
  2. Remove the rope.
Hope this helps you
Sep 24, 2009 | Garden
How do I replace the pull cord on a briggs and stratoon 1450 series snowblower? The are rivets which I've screwed out, but am having difficulty putting things back together
Since you have already removed the rivets, just go to the numbered portion of the instructions below and follow them to replace the rope.
To put the recoil assembly back on the blower housing, you will need to obtain a pop rivet tool and rivets or or 4 very short machine screws with lock washers and nuts and insert them from inside the blower housing so the flywheel doesn't hit the ends, and tighten them securely
  2. Remove the rope.
Sep 12, 2009 | Heavy Machinery
I Need to change the starter cord. How do I
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges.Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
  2. Remove the rope.
Sep 05, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
