Question about Sewing Machines
The bobbin thread is bunching up and sometimes
I am quilting a baby quilt with simple straight lines (I've made several) but today my machine is not cooperating. The bobbin thread is bunching up and sometimes loose in the same seamlines. My fabric is tucking on the underside as well. Help! I'm tired of ripping out seams...What should I do?
  • 208 Answers
Take the bobbin out and unthread the machine.
Install a new needle.
Place the needle bar in its highest position and place the presser bar up.
Make sure that the upper tension dial is in the normal range (5 or mark on dial).
Rethread the bobbin ensuring that the thread is in the tension.
Rethread the machine.
If this doesn't help, please indicate your brand and model for specific advice.
Posted on Jun 27, 2009
I am making a quilt on Husqvarna Lily 530 and cannot get my upper/lower thread equal for outlining design in quilt..book doesnot help me....any suggestions for stitch setting
Tension for stitching a quilt sandwich is tricky. It helps if you use the same color for top and bobbin thread,. If your quilting thread is not the same weight (either heavier or lighter) than thread used for regular sewing, then the bobbin tension may need to be adjusted. My quilting thread is lighter weight so I have a separate bobbin case whos tension has been adjusted specifically for quilting. The goal is have both threads meet in the middle of the sandwich. If the top thread is showing under the sandwich, you probably need to tighten the top tension so it will pull the bobbin thread up into the sandwich. Do the reverse if the bobbin thread shows on top.
It may also make a difference by changing the type and size needle. I tend to prefer a top-stitch needle. An embroidery or microtex may also work for you.
Machine Quilting Thread and Tension
Tension troubles on your quilting machine Try these tricks
5 Free Motion Quilting Problems and How to Fix Them
Mar 08, 2018 | Husqvarna Sewing Machines
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
Brother Sq9185 sewing machine, the thread on bottom just pulls out, when free motion quilting? how do I fix this
Sounds like the upper tension needs to be tightened, or the bobbin thread needs to be loosened. At any rate, the tension is correct when the two threads meet in the middle of the fabric for general sewing.
For free motion quilting, the tension should be adjusted so that the bobbin thread does not show on the top of the fabric, however, it should not lay in a straight line like it sounds like it may appear currently. What you are currently producing is a gathering stitch where the bobbin thread can be easily pulled.
Nov 16, 2015 | Generic Brother 130-Stitch Sewing and...
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
Started machine quilting; first pass went just fine, rolled up quilted portion, then started machine again but the bobbin thread broke and continues to break. Took out bobbin, reset it in case, etc. N
from what you said about the bobbin thread continues to break
check for burrs in the following area--even the smallest burr can cause problems
bobbin
bobbin case
needle plate
needle could be damaged
or bad thread
Feb 10, 2012 | Juki TL-98Q
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
The top rod of my Crown Jewel baby lock quilting machine keeps slipping, what can I do?
I am quilting on a Crown Jewel and having trouble with the tension. How do I correct for skipped, gaps on the top threads? I have adjusted the bobbin tension.
Oct 25, 2010 | Baby Lock Imagine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
330 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
