Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52in. Projection TV D52W19B does anyone
RCA 52in. Projection TV D52W19B does anyone know the procedure for dicharging the voltage from and removing the flyback transformer?
    Problem Solver:
  • 17 Answers
How do you know the flyback is bad
Posted on Sep 01, 2009
I have a HYUNDAI TV SET WTP-20 and I opened the back cover to repaire the main power button and now the TV look like ON but nothing happened when I want to watch a program.
Posted on Jun 29, 2009
    Genius:
  • 1,139 Answers
Hello butmommy03,
This is the procedure but first I must warn you. You are dealing with one of the most dangerous parts of a TV The High Voltage anode or the CRT and the flyback transformer. That being said this is what you have to do:
1) unplug the TV from the wall or power strip.
2) take the back of the TV, and find the High voltage trippler and using a screwdriver grounded by a clip-lead to the grounding strip touch it to the exposed metal of the input to the High Voltage trippler.
3) using a soldering iron de-solder and remove the wire from the HV trippler.
4) Once this is done, angle the chassis to expose the bottom of the Deflection board, if this is no possible you will have to remove the deflection board to get a look at the bottom, once this is done and you can view the bottom of the board using a soldering iron and a de-soldering pump you can remove the solder from around the pins of the flyback transformer about 10 pins in all. Then remove the screws that hold the flyback in place. this is the procedure you requested,
However again I must ask you not to do this yourself and to get a qualified TV technician to troubleshoot this TV for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 27, 2009
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
I'd like to find a free manual for an RCA Projection TV model # D52W19B
You can get a free pdf manual from RCA Support. Visit the RCA website at www.rca.com.
Oct 02, 2013 | RCA Televison & Video
I have a 52" rear projection TV. D52w19b. Green
Make sure you resolder the flyback and recheck any RCA fuses that may be blown - they are usually near the flyback. If this does not help check the site www.tvrepairkits.com for repair kits or tips for your projection tv model.
Apr 27, 2013 | Televison & Video
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 inch tv will not come on and has no sound
Right now i have two of theses sets in my shop and what i am finding out is they have big problems with bad flybacks and high voltage tripplers.both of these set have now shut down and will not come back on so how much is all these parts ,will post that when i find out!
Nov 25, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
477 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
