Question about Weber Genesis Silver B Grill
First burner on 3 burner weber grill will light but not the 2nd and 3rd
The number 1 burner lights but not the other 2 burners
4 Suggested Answers
  • 2976 Answers
SOURCE: Burner won't light
Clean everything up with a wire brush. The tiniest bit of debris in the ignitor area will prevent a spark.
Posted on Mar 14, 2009
  • 233 Answers
SOURCE: gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Posted on Jul 12, 2009
  • 464 Answers
SOURCE: Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Posted on Oct 13, 2009
  • 332 Answers
SOURCE: weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 30, 2010
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
My front burner on my silver b will not ignite also their isn;t any gas coming out.I can light the 2nd &3rd burner but the heat does not get higher than 350 degrees !!!!
The problem you're having is due to a partially locked grill hose regulator.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 24, 2011 | Weber Genesis Silver B Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Aug 06, 2010 | Weber Genesis Silver B Grill
1st of 3 burners will not light. The other two have gas flow.
blocked burner or gas injector or gas on off switch blocked
May 15, 2010 | Weber Genesis E-310 Gas Grill
Oct 12, 2009 | Weber Grilling
Ist burner will light, 2nd burner lights only after delay.
You don't say how old it is - could it be that the jet is corroded? They are only a few bucks to replace and are really the only part in your grill that controls how ignition happens.
Aug 20, 2009 | Weber Genesis Silver B Grill
Gas flowing to burners 1 and 2 but not 3
Jul 12, 2009 | Weber Genesis Silver B Grill
Ignition problem on 2nd and 3rd tube
You may have to take them out and blow the burners out with an air compressor. It is very hard to tell if they are stopped up internally.
Jun 04, 2009 | Weber Genesis Silver B Grill
Only enough gas flow for 1 of 3 burners
Shut off the tank and remove it from the grill. open all valves. close all valves. Reconnect tank to cooker and SLOWLY open the valve a hair. Then retry.Something in the dang newer safety tanks cause this phenom.
Mar 22, 2009 | Weber Genesis Silver B Grill
Burner won't light
Mar 09, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
116 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
