Question about T-Mobile Dash Smartphone
Wet phone hot battery
Ok so my friend gave me his phone mine broke he said he droped it in the spa it turns on but the battery get really really hot, i pluged it in i have it off cause i want it to charge, a yellow light appears for a min now a little red light is just flashing ? i cant find any trouble shooting in the guid? any advice
  • 97 Answers
Re: Wet phone hot battery
It could be a mixture of things......the main problem could have been the water of the spa.......the phone might be shorting out the might need to replace both. try the battery first. you can buy that real cheep off ebay for like 3.00
Posted on Jan 01, 2008
0 characters
3 Points
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Not powering on
Will it start if attached to a charging cradle directly?
May 21, 2008 | Toshiba e740 Pocket PC
My battery is always on 50% and when i connect the charger and the usb, phone is turning off
Mine has the same problem too. but its always 100% battery. its really awfull to see battery full message when plyggin into charger evn after the battery is completely empty. The solution that worked for me as well as for my friends is TO REPLACE THE BATTERY. good thing if ur device is less than 6 months old. otherwise u've to pay 4 it. Damn LG :-(
Jan 10, 2011 | LG KS20 Smartphone
Forgot password to Blackberry Curve
No need to asking that password to your friend of your friends. you can unlock blackberry curve password even you don't know your previous password, but you will lose all your previous data in that phone. If you ready just type any password until your reach 10 failure of password, that will make your blackberry unlocked from old password so you can setup new password again for your phone.
Apr 28, 2010 | AT&T Blackberry Curve 8300 Smartphone
Blackberry went dead after droping in sink with water
You can try to see if it will work after drying it out completely.
But yes - most BB's will stop working once exposed to water. Thats why they put those little white square stickers in the battery compartment. Those turn pink or red when exposed to moisture. That way the cell phone companies can see when you got your BB wet - and they don't cover liquid damage.
Jan 05, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve got slightly wet, now cant turn on
Problem was when you got it wet, you did not let it dry long enough. Reason I say this is because when you tried to operate the phone again it shorted out.
Typically it takes about 48 hours to dry completely. The best way is to separate the battery and phone, put them in a bowl of rice and close it up for 48 hours. The dry rice will draw out every bit of moisture.
You really can't do much to fix it. Paying an expert to look at it find the damaged parts and replace them would cost many times over that of replacing it.
Oct 03, 2009 | RIM BlackBerry Pearl Smartphone
Locked my blackberry 7290 and forgotten password
You can just enter the wrong password 10 times and it resets.
Jan 23, 2009 | RIM BlackBerry Pearl 8100
LG viewty ku990 - no battery life and phone gets really hot
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Dec 26, 2008 | LG KU990 Viewty
White screen even after software update, please help?
Well, after doing more research, I found the answer! You need to buy a new LCD screen for your blackberry. I bought mine on eBay, i.e.
Make sure you get a screen with the tools, there are very small hex screws, but my tool sucked and I barely got the screws back in. There is also directions on youtube on how to replace the screen, you will have to take your whole phone apart. But it fixed my problem and my phone has worked great ever since.
I also got a rubber case to put on my phone, I have a TERRIBLE habit of dropping mine (hence why my screen broke to begin with) but I have dropped my phone a few times since, and the rubber really protects it, I got that on
Anyways....good luck! :)
Jul 10, 2008 | RIM BlackBerry Pearl 8100
Blackjack cell phone AT&T won't charge or turn on
Go back to AT&T, or find somebody else who has a Blackjack II and put thier battery in the phone to see if this 'jump starts' it. I have had the same problem now 3 times. There seems to be a consistent issue with Blackjacks just not charging after a while, then the battery runs down and you can't turn the phone on again. 1st time AT&T put a new battery in mine and it turned straight on! 3 weeks later it happend again and they gave me a new phone AND another new battery. 3 weeks later the same thing has happened again with thenew phone. Never seen this happen with any other phone model.
Jun 26, 2008 | Samsung BlackJack Smartphone
T-Mobile Dash Smartphone Logo
99 people viewed this question
Top T-Mobile PDAs Experts
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
