Question about Coffee Makers & Espresso Machines
Maxkon SK 201A Coffee machine only has one rubber pipe
Maxkon SK 201A Coffee machine only has one rubble pipe.
the booklet says it should have two rubber pipes to be immersed in the water but my new one only has one. this seems to make the steam nozzle work but no water is coming out of the actual coffee filter part?
Hi - had same prob= found out modern maxcon machine has only one tube in water tank- other is internal. turn steam knob to off position- anti clock - and wait till water / coffee light is green- then water will come out from filter . when wanting the steam- turn the steam knob clockwise - hope this helps - susan
Posted on Dec 14, 2009
    President:
  • 3,433 Answers
Call the manufacturer ha have them send you the missing componant. They usually do that. Good luck. And send them a copy of the print saying its needed.Call the machine evil.
Posted on Jun 28, 2009
I have a K15 coffee maker and the water does not empty as i get not even 3/4 cup coffee.I do find water in the tray
main line is clogged ;) unscrew the machine find the main line ( rubber pipe ) and clean it out
May 01, 2017 | Coffee Makers & Espresso Machines
I need an instruction manual for a DMC image transfer machine model GT-201A.
I have a DMC Image Transfer GT-201A in the box, never opened.
If you would like it, please contact me (dvrbon@wi.rr.com)
Aug 18, 2011 | Cameras
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
How do I know that I have a Maxkon Product? How can I contact Maxkon? There is no proof that I received even a Maxkon product. The inststruction Brochure is never mentioning the Word "Maxkon",...
can you explain or email me an maxkon ice maker information booklet or tell me why the defiencey light keeps coming on
hopeing you can help me out
Nov 12, 2010 | Coffee Makers & Espresso Machines
Filter basket sticking in the group head
It sounds like the solenoid is not discharging after a coffee is made, try back washing machine with purocaff. If the soap comes out of the small pipe on the right and dumps into the drain tray you are back in business if not you might to clear the pipe.
May 11, 2009 | Pasquini Livia 90 Espresso Machine
Reads decalcify, brew unit missing- and wont make coffee!
Hi
Open you door on the right. Push on the upper left side of your brew unit and see if it will click. You have to push fairly hard towards the center of the machine. If it clicks the outlet pipe needs to be lubricated. The outlet pipe is the angled pipe on the top left side of the brew unit in the back. Lube the end of the pipe with food grade not food based lube.
Apr 27, 2009 | Saeco Royal Digital Plus Coffee...
Coffee not coming out of the front taps, coffee & waste beans both ending up in the waste tray, can you please advise thankyou. model type 889
I had the same problem. The pipe that delivers the coffee brew is plugged, therefore, the brew leaks back in the waste tray. You need to take the top cover only. Then you will see a silicone hose. You need to pull the hose out of the head pipe. You can remove easily the head pipe as it snaps on the pipe that delivers the brew. What I did was to run the descaling program. Then inserted a thin stiff wire during the cleaning process and gently pushed the wire a few times to remove the obstruction. You have to be careful. Once the obstruction is cleared steam or liquid will come out of the pipe with some pressure. Then stop the cycle and run it again once the head pipe and top cover are replaced. Although there are no electrical wires visible when you take the top cover you need to be careful and wear rubber gloves and goggles. This worked for me and it was probably due that the machine was not used for sometime and the coffe brew plugged the delivery pipe. Good luck
Mar 01, 2009 | Krups Orchestro 889 Espresso Machine
Water leaking from bottom. what's up?
the best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Jan 16, 2008 | Starbucks Saeco Italia Digital Barista...
Meile cva620 coffee machine
Take a sample of the teflon micro pipe tubing to your local plumbing store and ask them to match.
The larger clear tubing is a type of surgical rubber, try a local model shop.
Either way the piping must be suitable for food use (don't use car parts gas hose!).
These guys will supply:
http://www.wmtubing.com/?gclid=CO6ej_Gl2JACFSCBEgodnhxMWA
Dec 12, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
443 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
