Every time I go to use the VCR , the blue screen comes up with the message VCR Lock Activated. This negates any further use of the VCR until I deactivate the VCR Lock. I'm sure the manual covers this problem but unfortunately I can't find the manual. Do you have a solution? Is there a switch or a proceedure to follow to deactivate the lock.
  • kgshore Jun 27, 2009
    In answer to your request for informtion. The make of the VCR is Panisonic. Model # PV4662K Serial# K6SA40952. Hope you can find the answer to the problem in the manual.
    Thanks------Ken.
  • 1,272 Answers
Hi, follow the below instructions to enable or disable VCR Lock:
To turn on the VCR lock follow the procedure below:
In Stop Mode, Hold down REC on the VCR without a cassette inserted for 7 seconds.
To turn OFF VCR lock follow the same procedure as stated above.
If you require the manual for this VCR then please let me know, I will send you the link.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 27, 2009
  • Anand Gupta
    Anand Gupta Jul 22, 2009
    Has the issue resolved? If not, then please let me know so that we can work for a solution!
    Regards
    Anand
  • 10,594 Answers
Please intimate exact model and brand of your VCR to find user manual or info to deactivate lock in it.
Thanks.
VHS tv says DEW lower left hand side, how can I fix this problem???
If the message comes out of your VHS tape recorder, means that humidity is present near the upper drum cylinder.That will stop the VCR from further actions because of danger to lock the tape on the head's surface.The proper actions are to blow inside hot air maybe from a hair dryer or remove cover and place the vcr on a sunny area for 30 minutes.If the error message continues then there;s nothing for you to do .Must take it to a nearest service because a faulty sensor or even a connector is displaced and needs a service person to act further on this.
Mar 02, 2015 | Video Cameras
VCR Lock Activated message appears when I hit Play. Why and how do I get rid of it so I can play a tape?
<b><font size="1" face="Helvetica-Bold"><font size="1" face="Helvetica-Bold"> To turn on, </b></font></font><font size="1" face="Helvetica"><font size="1" face="Helvetica">hold down<br /> REC on the VCR in Stop<br /> mode with no tape<br /> inserted for 7 sec.<br /> (Please ignore the NO<br /> CASSETTE warning.)<br /></font></font><b><font size="1" face="Helvetica-Bold"><font size="1" face="Helvetica-Bold"> To turn off, </b></font></font><font size="1" face="Helvetica"><font size="1" face="Helvetica">repeat above<br /></font></font><!-- from fixya rte -->
Nov 22, 2009 | Panasonic PV-V4022 VHS VCR
Vcr lock activated
Hi There,
Try unplugging it, wait 2 minutes, then plug it back in. Let me know if it clears.
Mar 29, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
VCR Lock activated-Can I turn it off?
Turn the VCR on and remove any tape. Press the record button and the VHS/TV button simultaneously. You should see a message saying the VCR is unlocked. It worked for me.
Aug 18, 2008 | Quasar VHQ720 VHS VCR
Vcr lock activated
What brand and model of VCD is this?
Dec 19, 2007 | Quasar VHQ401 VHS VCR
Language Selection
I had that happen. I found out that I had the VCR turned on. So I turned that off and The language select went away.
I was connected from satellite to VCR then TV.
Nov 14, 2007 | RCA HD52W59 HDTV Projection Television
I Am Having Trouble Tuning My Channels On My VCR.
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Nov 12, 2007 | Sanyo VWM-800 VHS VCR
How to unactivate 'vcr lock' ?
Generally, if you aim the remote at the VCR with the STOP button pressed, for around 10 seconds, the VCR gets 'unlocked'. Try it.
Feb 25, 2007 | Panasonic PV-7451 VHS VCR
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
