Turns on kicks in but no fan - Heating & Cooling
    Sergeant:
  • 340 Answers
Bad relay bad capacitor or bad fan motor. good luck Tom
Posted on Jun 27, 2009
My 1998 lexus e300 is running hot and I noticed the cooling fans are both running but at low speed. what controls the fan speed
The PCM(computer) controls the fan speed. Low speed comes on around 200 degrees, high speed kicks on at around 225 degrees. If they come on when you first start the engine, the coolant sensor is bad. PCM is in default mode and runs the fans all the time. Since it doesn't read the 225 mark, it won't kick on the high speed. Turning on the A/C will also kick on the high speed fans. That's if your A/C works.
Jun 21, 2015 | Lexus Cars & Trucks
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Fan dont work but when i turn on cooling system two fan work please give me lay out for cut-off and fuse
If you have two electric fans the fan on the passenger side of the vehicle is the radiator cooling fan, that fan should run when the motor gets to hot. The fan on the driver side is the ac condenser fan that fan runs only when the a/c is turned on. The only time that both fans run is if the a/c is on and the motor or coolant is above normal tempeture.
Aug 15, 2011 | 1995 Hyundai Sonata
Daewoo lanos 98 model. Only one radiator fan works, which is overheating the car.
only one is suppose to work the other kicks on when you turn ac on turn ac on does it come on now let me no and i can help you more from there check water level do you have the correct amount of water in resevior of car when car heats up half way fan kicks few minutes later fan should kick off with ac off of course sticking thermostat can cause car to over heat
Dec 08, 2010 | 1999 Daewoo Lanos
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
Our fan wont kick on , you can do it manually
sounds like your plenum temp sensor is pooched. once your plenum gets to a certain temperature then a sensor closes, telling your fan to turn on, if the fan doesn't turn on then the flames will be shut off by the high limit switch witch prevents your plenum from burning up.
Jan 24, 2010 | Coleman Propane Forced Air Heater...
Unit won't turn on
WHEN A COMPRESSOR FIRST STARTS TO RUN THERE IS AN INITIAL HIGH STARTING CURRENT(30 AMPS PLUS),BUT THIS SHOULD DROP BACK DOWN TO RUNNING CURRENT PRETTY QUICKLY.IF IT MAINTAINS THIS HIGH STARTING CURRENT FOR A WHILE THEN THIS GENERALLY INDICATES THE COMPRESSOR AT FAULT,BUT!!!!! ALSO CHECK TO SEE IF THE FAN IS NOT SEIZED. DISCONNECT THE FAN ELECTRICALLY THEN RUN THE UNIT. IF THE STARTING CURRENT MAINTAINS APPROX 6 AMPS THEN THE FAN IS AT FAULT!........HOPE THIS HELPS!!
REGARDS........BIGGGAZZ
Oct 15, 2009 | Dometic Rooftop RV Air Conditioner
Car is overheating, Fans wont turn on
First are you sure the fans are good. Unplug the fans and hook directly to the battery and see if they turn. One fan is for the engine and should come on when the car gets hot. The other generally comes on when the a/c system is on. If both fans work hooked directly to the battery they are good go to the cooling fan switch or temperature switch (same thing different name) and make sure it is good. This tells the fan to kick on when the car gets hot. The other one kicks on when a switch on the a/c system tells it to kick on. Check and make sure you are getting power to the fans. Get a test light and ground it to a good ground on the car and probe the plugins going to the fans and insure there is power coming to them when the car is running. If no power fuse is bad or the sending unit is bad.
Oct 06, 2009 | 1999 Toyota Camry
Inverter fan kicks on after turning on a light bulb
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
