Question about LG 42PC3RA 42 in. HD-Ready Plasma TV
TV screen goes green - LG 42PC3RA 42 in. HD-Ready Plasma TV
  • Obertelli
    Obertelli May 11, 2010
    When? All the time? After a while? Intermittently? In any case, this model is only about two years old so may still be on the manufacturer's warranty.
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Mar 18, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Need to take off tinys green dots in my screen tv.
It seems that your DLP Engine is going. The DMD board in the engine is the problem. it is an expensive fix
Jun 29, 2008 | Olevia Televison & Video
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Rca Goes Green
replace video ic on Green CRT broad,also look for leaky capacitor on same broad replace it also, If this does not fix it then you have a bad green tube!
Nov 29, 2007 | RCA HD52W59 HDTV Projection Television
LG 42PC3RA 42 in. HD-Ready Plasma TV Logo
175 people viewed this question
