My Acer 3620 overheats after a couple of hours of use and gradually slows until it totally freezes. Is it fixable?
  • 334 Answers
You need to make sure the fan is running and you need to clean the heat sink. you can try to blow it out with canned air the best thing to do is disassemble if you are to the point of overheating.
seth
Posted on Jun 27, 2009
    Sergeant:
  • 280 Answers
If your laptop heats up in normal circumstances, there might be dust accumulated in the fans and heat vents. Take your laptop to the nearest service center or any computer shop (if it is out of warranty) and get it cleaned. Also when you're working, make sure you dont block the heat vents in your laptop.
Commercial fan on evaporator cuts off after starting
There is an overheat klixon on the evaporator that stops the fan running until the coil gets below -11c This can take some time after startup. if the freezer runs more than an hour before the fan starting, check the klixon isn't faulty, and you have power to the fan. Also check the condenser grille is nice and clean as it will slow down the freezing process.
Apr 17, 2014 | True Freezers
Freezing
A computer/notebook/laptop can freeze due to a lot of reasons. Here are few noteworthy ones. Check them and see if they help, if not then post a little detail of when it freezes more etc:
a) Antivirus programs have a great tendency of eating up memory quite quickly. So, get a lightweight antivirus program like Microsoft Security Essentials or Avast etc.
b) If you have a low RAM then it is recommended that you run very few applications at the background. Avoid running any unnecessary applications.
c) If you have a desktop set with lots of transitions and effects it can cause huge RAM and often results in freezing of system.
d) Your O/S could be a problem too. If the above things doesn't help try resetting/re-installing the O/S and hopefully it shall help you a lot.
e) Check your system for any viral activities. You can perform an online scan using many free online scanners like Trend Micro etc.
Oct 24, 2012 | Acer Aspire 3620 Laptop/notebook
Frozen acer aspire 3620
Sub out the ram memory one at a time to see if this will resolve the problem.
Sep 03, 2012 | Acer Aspire 3623WXCi Notebook
Acer aspire 3620 window problem..bios password forgot how to install new window
mmm for me the best solution is reinstall de windows, to recuperate the password is so hard.
Oct 11, 2010 | Acer Aspire 3680 Notebook
Loading too slow and processing
Please run system restore to factor default setting and remember to backup your documents.
Rate this solution.
May 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire playing music & video too fast, chipmunk speed.
Go to your sound card settings under start settings control panel, select the real tek audio then in there there should be settings on how your sound comes out of your computer make sure that it is not set on some funky audio morphing setting. Someone must have played some pranks on you but yes its total fixable with a couple strokes of the mouse. ruldss2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 05, 2009 | Acer Aspire One PC Notebook
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Adding an external monitor slows down my laptop to a crawl.
Looks like you have a memory leak of some sort. Press Ctrl+Alt+Delete on your keyboard, and task manager should come up. If your computer is set up differently, then a dialog box will come up with a six buttons on it, you should click on task manager. Go to the preformance tab, and you should see your memory usage. If you go to the Processes tab, you should be able to see which process is using the most memory. From then on (depending on whether you have more or less computer experience) you should be able to solve the problem yourself. If you don't have much experience, just report back with as much detail as you can manage.
Dec 02, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3620
I hope this helps:
This first link is for windows vista, if thats what you are running
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-3620-Bluetooth-Driver-601.shtml
now the this one is for windows xp: click the link and then click the little green box on the left witht he arrows pointing down.
http://www.notebook-drivers.com/ViewDownloadUrl.asp?ID=87869&brNum=3&show=0
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
