I have a vintage Scott stereo receiver 370R. I need instructions for wiring the antenna and ACC on the back. Can't get good radio reception
techman
  • 3130 Answers
SOURCE: No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Posted on Sep 16, 2006
  • 4 Answers
SOURCE: Radio reception
If antenna optimization didn't work you'll probably have to move.
Posted on Dec 14, 2007
sapperj
  • 70 Answers
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Posted on Jan 11, 2008
robotek
  • 1512 Answers
SOURCE: I just bought an old
Any luck with checking antenna connections? I have a service manual if you need it. Tuner section in this old girl predates the LM7001. Uses ha1137-38 chips, bit more complex to repair.
Posted on Jun 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: poor AM car stereo reception with new DP AudioVideo player
AM.... what the heck is AM??? LOL
Check the antenna connection behind the radio to be sure it is taped and not touching ground. Also the antenna & cable running to it for worn spots in the shielding, or corrosion.
I think (based on knowing how manufacturers do things at times) that their is a very cheap universal chip type tuning system in play here on the order of about 10 cents value that many manufactures are probablly incorporating these days. What I did to solve this annoyance was to purchase (after many tests) a SHARP brand walkman type AM/FM hand unit that has really good AM and jack it into the preamp section before my crossover (added an extra input via Y-adapters) and use Ni-metal-hi batteries that can be recharged. I get about a week out of the 2 AA cells. I also had to build a rather good cable (shielded) to go from the unit to the 1/8 jack to cut noise a notch more. This has proven a good situation for me.
With this knowledge, I wonder what head units actually have good rejection circuitry and great gathering power for amplitude modulation?
Posted on Jan 08, 2009
I have had a pioneer X-ray p970 f model.. had it for years. However getting radio reception has always been an issue. I live rurally. I would like ABC AM 720. Any ideas. Thani you Susan
A web search for your model turned up a blank. You aren't kidding about having it for years. I'll give you some generic information about AM radio reception and hope you find something useful.
Generally, AM reception is through a wire coil wrapped around a ferrite (very fast magnetic material) rod. Received signal strength is dependent on the angle between the rod and the radio station's transmitter antenna, so rotating it in a horizontal direction (around an imaginary vertical line through the center of the receiver) is often helpful. The angle of the best direction can be affected by nearby equipment (metal appliances, ductwork, computers, etc.)
Many non-portable audio receivers and a few boom box types have both an AM and and FM antenna terminal on the back. The FM antenna is very much like a TV antenna (you can use a TV antenna) and is generally required to get FM reception except in units with a telescoping antenna mounted to the case. The AM antenna is used to augment the coil signal, and is generally needed only if you are trying to pick up a weak signal. Attaching a wire to the AM terminal may help (make sure you have a good electrical connection between the terminal and the metal of the wire). This wire will also have an optimal angle for best reception. Try arranging it vertically; many AM radio stations transmit vertically polarized signals for the benefit of car radio antennas.The longer the wire is, the better, but it doesn't have to be very large. The physical limit is about 110 yards, the practical limit is how much you can stand to have stretched out behind the stereo. (A thin wire going up the wall to the hook behind a picture will probably not attract much attention.)
Portable radios often use a single telescoping antenna for both AM and FM along with the internal coil previously described. If you have this, experiment with antenna position and radio location. I have been told that some early model LED light bulbs may interfere with AM radio reception, especially if they are within a few feet of the radio.
Feb 26, 2018 | Pioneer Audio Players & Recorders
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Apr 20, 2012 | Pioneer Audio Players & Recorders
The FM antenna is insufficient. I there a way to improve reception? Another antenna that will fit?
To improve reception, use a 75 Ohm outdoor antenna instead of an indoor antenna. Disconnect the indoor antenna before replacing it with an outdoor antenna.
Dec 14, 2010 | Insignia 200W Stereo Receiver
Lost ariel reception hookup
Any car stereo shop should have what you need. Might be a special antenna adapter for certain vehicles.
Jul 06, 2009 | Sony CDX-GT710 CD Player
Bad reception
Sounds like you have an antenna problem. Find where the antenna plugs into the radio. Unplug it and find a nail or something the same diameter as the center pin wrap about 3-5 turns of a four foot piece of wire around the nail and plug the nail into the antenna input on the radio. If it clears up reception you have a bad or grounded antenna. Follow the antenna wire back to the windshield or fender etc. mounted antenna, sometimes there are other plug in points that get knocked loose.
Jan 12, 2009 | JVC KD-G720 CD Player
Radio Problem
There is not an easy answer for this one. Some troubleshooting needs to be done. I have seen the Rockford Fosgate system in many of the newer Sentra's. Try hooking a known working speaker to a nonworking position. This will tell if it is a speaker problem. If the problem persists, this could be stereo or amplifier.
Terrible reception troubleshooting, a bad antenna will give poor FM and no AM. If both have bad reception, this is a stereo problem. You can remove the stereo from the dash, place a small pick tool or screwdriver into the antenna jack and test reception. If the reception problem clears, this is a antenna problem. I have seen car detailers pull the connector from the rear window antenna and forget to plug it back in too.
Nov 10, 2008 | Car Audio & Video
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
AM/FM stereo receiver often fully "drops" the reception of listened to radio station(s), or reception will often decrease in volume. Repositioning of the receiver's connected antenna wire often has no...
Possible solution. I have fixed two with this problem. When the radio drops to a hard surface, the ferrite coil antenna is the heaviest component on circuit board. Look for cracks in solder or broken wires where attachments to circuit board occurs for this component. Use a fine point soldering iron with low heat.
Oct 12, 2008 | Audio Players & Recorders
I NEED AN ANTENA FOR PANASONIC SA-PM32DB
If its a one wire or two wire FM/AM antenna your needing just use a length of regular stereo speaker wire or electrical wire at least 5foot in length. Should do the trick nicely.
please rate answer.
Mar 18, 2008 | Audio Players & Recorders
578 people viewed this question
 Grubhead
Grubhead
