****. IBM just wants your money. In most cases, the bios password can be disabled by removing the CMOS battery. Remove the CMOS, pull out the power cord, and hold the power button for 10 seconds to drain any residual charge. Boot the computer without the CMOS and it should say password disabled. Turn it off, unplug it, and slap it back together. You should be fine. Let me know how it goes.
there is no default password for that you will need to open up the laptop and remove the cmos battery inside to bring the bios back to its factory settings (without password). sometimes tho dell will add password , dell , or admin as a password. but thats usually for laptops and pcs they sell in bulk to businesses PLEASE let me know if this helped and sorry for the bad news about having to open up the laptop
You should be able to. If you have an admin password you will have to log in using that password and then change it. If, instead, you are saying that there is a password and you don't remember it and therefore can't log into it, then you'll have to pull the battery and probably short the jumper that clears CMOS.
var fctb_tool=null;
function FCTB_Init_b6b8929221874249b8e059dc7050e02e(t)
fctb_tool=t;
start(fctb_tool);
var fctb_tool=null;
function FCTB_Init_b75fc654268d44e88831c5ee986a4a1b(t)
fctb_tool=t;
start(fctb_tool);
what kind of password, admin password or cmos password? if cmos password reset the password by removing the cmos battery.. if admin password use program for removing the admin password
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Yes, If you know the routers' administration password, you can log in to the administration settings and change the password. If you are asking if you can change it without knowing the admin password, not likely.
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios. For reset bios u have to open back side of your laptop then u find motherbord circuit there. pull cmos cell on motherbord for 15 minute then it reset to defaults. Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear" It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset. then again set it in 1-2 its original position. Then it not want password.
And if u tell about windows password Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password. But if u set and forgot default administrator password then u should need winxp recovery disk.
Are you talking about the operating system admin password, or the bootup CMOS settings password(s). If it is windows, you can find the administrative password by downloading one of the freeware utilities at this link:
If it is the CMOS password, you can reset it by removing the coin battery on the motherboard on the laptop (this can be *very* tricky depending on the laptop make/model)
