Speakers are connected but there is no sound - Audio Players & Recorders
  • Johnnycat May 11, 2010
    Not much information given. When you open your sound/speaker properties on the pc, do you have sound muted, turned down, anything like that? What have you tried up to this point?
  • 112 Answers
Your do not have a sound driver on your computer then. try installing a sound driver
Posted on Jun 29, 2009
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I have plugged in the USB from my Zalman 5.1 External Sound drive and I still do not have sound. Should it be connected to my computer speakers? If so where? I have two current plugs on my speaker; the...
Yes, the speakers must be connected to the device. Your speakers use an older color code for connections. The black plug from your speakers goes in the green socket on the device. There may be a black socket on the device, but due to the color changes, black now indicates a surround speaker connection, not the main speaker connection. I would guess, not seeing your speakers, that the tan plug is either for a microphone, or more likely, is how you connect the left speaker to the right one.
Mar 14, 2011 | Zalman Tech Zalman: Zalman External 5.1Ch...
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
No sound
There are a number of different reasons why your computer may no longer give sound.
Check the Speaker Connections and Volume Control Settings
Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
Read more: How to Fix a No-Sound Problem From Computer Speakers ' eHow.com http://www.ehow.com/how_2225072_no-sound-problem-computer-speakers.html#ixzz11nkQCSL4
Oct 08, 2010 | Computers & Internet
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
I don"t hear any sound from my speaker i connected to my pc all my setting are correct
hi
I read your problem.
your problem is that you don't hear any sound from your speaker when you connect to your pc and you also say your setting are correct.
but again you check your setting in my way
  1. Go to control panel
  2. than go in your sound option
  3. than check your speaker wire pin is connected properly if not than connect it properly
  4. is your computer show your speaker are connected properly
  5. than there is a option to test or check your speaker means it when you click your left speaker create sound than right
  6. if you hear sound means it is correct or your hear only one side than check your volume option
  7. if you don't hear any sound it means your speaker is dead.And also connect nearby computer shop.
Apr 02, 2010 | Computers & Internet
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
No sound
Is the speaker with no sound, actually connected to anything? (if it's connected to the first speaker, it's possible that the speaker is simply dead and needs replaced)
May 26, 2008 | Inland ProSound 1000 Computer Speakers
Sound from one speaker only.
your output stage had a problem in electronic output device and must be maintained in service center.
Nov 03, 2007 | Audio Players & Recorders
144 people viewed this question
 Grubhead
Grubhead
