I have a Mitsubishi WD-62530 tv. Yesterday the tv remote was working fine. Today I can't turn the power on or off, adjust the volume or change the input (to watch a dvd from our dvd player). I have hit the reset button on the front of the tv, and it was no help. I have changed the batteries in the remote and it was no help. I tried to adjust the volume by using the volume buttons on the front of the tv and they do not work either. Any suggestions?
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at [email protected] if this helps
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
SOURCE: Can you please explain how
http://www.youtube.com/results?search_type=&search_query=915P043010&aq=f
Hope this helps like it helped me.
