Question about Philips DIRECTV R15
Fails External Test - Philips DIRECTV R15
    Problem Solver:
  • 4 Answers
I would love to help you ... what are all the symptoms
Posted on Aug 14, 2009
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Gateway solo 1450 laptop will not power up.
1. remove main battery and test with just ac charger.
2. test ac charger with multimeter or test notebook with good charger.
3. remove any memory, then test each stick once at a time in each slot.
4. if only 1 stick, get and test with a known good stick, in each slot.
5. plug into external monitor and then power on to test if its a screen issue.
6. clear bios - usually by removing main AND BIOS battery, wait 5 mins.
7. remove all hardware - hdd, odd, wlan, modem, etc and test.
8. remove mainboard, reseat cpu, benchtest
9. test power is getting past DC port - ie, DC port is not broken...
if fails on bench after clearing bios, reseating cpu, with different sticks of memory tested in each slot, with a known good AC charger, and dc port is undamaged, the board is faulty.
hope this helps.
May 19, 2012 | Gateway Computers & Internet
WHen I hook my laptop to my external HP 22" monitor, using my HP docking station, it recognized the monitor but the externalk monitor stays dark. Every so often it will flicker and then give the...
no laptop stated ok W7 OS, nice to know.
hopeless?
nor external model screen stated
try a different external screen
any shop can fix it, ask them
no need to ship anything
get it checked out by a technician
we can test all 3 parts and tell you whats worn i minutes.
i can not understand your post
try to be more clear
does local LT screen work ok
does using a known directly connected screen (VGA)
on the LT you must turn on external screen using the fn hot key
the the external works,. do so, now
if both internal and external fail the LT is bad, guess, bad GPU chip
if only external fails, try a known working external screen
if that works your external is bad.
the docking is last, and if only it fails, then ITS BAD.
Mar 14, 2017 | HP Pavilion DV6910US Laptop
95 lumina over heating
Before the head gasket is condemned, the coolant fan operation should be checked, the fan should come on when the temp reaches 226 f degrees or 3/4 of the way up.
If the fan doesn't work I would replace the coolant temp sensor for the computer. Get a coolant pressure test done and if the pressure drops with no external leak I would also get a block test done if the block test fails then the head gasket is faulty.
Now if the pressure test is good I would replace the radiator.
Keep us updated.
Jul 03, 2011 | 1995 Chevrolet Lumina
How do I test my computer speakers
In built speakers??
1. Play any music
2. If it fails then check the drivers.
Get the latest drivers for your machine (go to HP official website under support > Download drivers
choose the model of your hp and download the sound drivers!
3. if it fails try external
4. if it fails change sound card
Jun 15, 2011 | HP Audio Players & Recorders
Acer model 5535 fails to start up theres no bios, no screen and few of the LED's come on
Any beeping? Sounds like a motherboard failure or memory issue. Can you test it by connecting to an external monitor
Feb 28, 2011 | Acer Aspire 5535-5050 Notebook
The lower part of my lcd is not showing
Hi
Confirm the issue lies with the screen and not the graphics chip by testing the laptop connected to an external monitor, if you get a good diaplay on an external monitor, then the screen backlight and maybe the inverter is damaged, it could also be a faulty VGA cable. The only way to test this is by replacing the screen.
If however it fails to display correctly on an external monitor, you have a failing graphics chip
Jan 03, 2011 | HP 435768-001 - Compaq Presario C300...
G60-230US PC Notebook died. It reads: "No bootable device--insert boot disk and press any key" on startup. startup test failed: "there is no hard disk."
It means that your notebook is not able to detect any hard drives or a bootable drive
also plz check if there are any cd/dvd or any external devices like flash drives or external hard drives connected to the nb.. If so disconnect all the external devices and try to boot up ..
If it does'nt work go to the bios screen by continiously tapping F10 or F2 or DEL key as soon as you turn on the nb and check if the hard drive is detected or not.. if its not reset the hard drive and retry.. If the hard drive is detected run a hard drive self test if it fails.. replace the drive if it passes run system recovery
Hope it works
All the best !!!
May 06, 2010 | HP G60-230US Notebook
Distored sound
distorted sound from external speakers or internal speakers?
isolate please. remove external speakers if you have one. just troubleshoot on the internal speakers alone.
uninstall the audio drivers. install the latest one. if fails. download then flashed the latest bios.
run diagnostics extended test to check the internal speakers. if also fails then replace the internal speakers.
Dec 05, 2009 | Computers & Internet
Cant connect phone through usb on 1525 dell?? wont read anything when i plug it in ?!?!?!?
Did it worked before?
Test the USB ports first. Update BIOS download it from the Dell support. Try a different USB devices like flash sticks, external storage or other USB devices. If all external USB devices fails USB port might be defective. Call dell to replace motherboard.
Oct 01, 2009 | Dell Inspiron 1545 Notebook
Philips DIRECTV R15 Logo
305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
