Question about HP VGA Webcam
Installation of hp web camera of usb port into my pc
I havae trying to fix a hp web camera of usb port into my pc and have even tried with the help of instruction cd, yet unable to fix it up. can you please help in fixing it up
  • 6 more comments
  • Deanna3 Dec 29, 2007
    need the software to reinstall my web computer was wiped clean because of someone hacking into it.. Thanks Deanna.
  • Anonymous Feb 09, 2008
    no funktion
  • d_livingston Mar 03, 2008
    i cant install it need a download program
  • Anonymous Mar 05, 2008
    i want solution.
  • Anonymous Mar 08, 2008
    i have purchased one hp webcamera in shop. that no is MM WC 117 . in that box there is no installation CD. can u arrange or give some solution for this problem
  • natz1026 Aug 04, 2008
    my web cam is on but i dont see it on my pc
  • Anonymous Aug 19, 2008
    i nee installlation of driver my web cam hp
  • marvin Torres
    marvin Torres Jan 03, 2014
    give the model number and then i will tell you or send the website if where you need to download the driver of your cam
I need reinstall my webcam but i have lose my cd and i can install the program... help me thanks
Posted on Mar 10, 2008
HP Printer Usb port in my Acer Laptop , shortcircuits my house
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
My webcam comes up blank, grey screen with no images..
Here are some suggestions:
  • Try unplugging the camera, uninstalling all of the software and drivers, then getting the latest from Creative and reinstalling everything.
  • Try installing the camera on another PC to see if it works there.
  • If you're connecting through a USB hub, disconnect it and plug the camera in to the PC's USB port.
  • Check the Creative web site for known problems
  • Send Creative (CHECK WITH YOUR MANUFACTURER)  tech support an email to see if they have any advice.
click this link for more info
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 20, 2009 | Computers & Internet
When my HP laser printer is connected via usb cable, my other usb ports dont recognize my sony digital camera when I try to connect. However, when I disconnect the printer and then connect my camera, the...
it is a hardware conflict, there is no way to fix it, unl;ess perhaps, you had a seperate usb controller for the printer. it is a pci card which you would have to install, and even that is not guaranteed to work.
Feb 20, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Pc camera dose not work properly even if software is installed.
there is a web cam mode in the camera settings put it on webcam mode check the settings in camera , and then connect it to ur computer actually u are connecting in usb mass storage mode it will only allow u to copy pics to ur PC for webcam if ur camera supports it u should have this mode in ur camera menu check and then connect it thru usb see if it works ok
pls vote fixya if i fixed ur problem
Feb 02, 2009 | Vivitar ViviCam 5355 Digital Camera
Computer not recognizing web camera
The only other thing that I would suggest you try to do is (if possible) goto another PC or maybe a friends PC and plug the web cam in. If it does the same thing then the web cam no longer works. If it does work, then you may want to try another USB port on your PC.
Jan 23, 2009 | Logitech Webcam
Web cam pluged in wont turn on
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | HP Pavilion ze2000 Notebook
Webcam gigaware 25-234
You need to go on line to the manufacture and download the VISTA driver for your camera and then follow this info to install.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 30, 2008 | Radio Shack VGA PC Camera Webcam
Image quality wit logitech quickcam chat
Normal 0 You need to go to the manufactures site and download the XP or VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Jul 29, 2008 | Logitech QuickCam Chat Personal Web Camera
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
Help me
1:)Do you have installed driver?
2)The green light on webcam working???
Nov 01, 2007 | Radio Shack VGA PC Camera Webcam
HP VGA Webcam Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
