Question about Kenmore 57029 Side by Side Refrigerator
I have a kenmore side by side and the electrical connection (box ) hooked to the compressor is burnt up. How do I tell if comp. is bad? Refride 5 yrs mold
  • dgpark Jun 27, 2009
    model # 106.54512300
    President:
  • 1,136 Answers
Hi, If this unit is under 5 years, I would check on the warranty. These models have an issue with the relay burning out. Most likely it is the relay/overload switch. You can replace the switch and see if the compressor starts. If you call a repairman, he can test the compressor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
  • Kenmore Master
  • 4,655 Answers
I will help you test your compressor. I also will need the model number that Sears uses to identify their models. 213.256489 for example. Sea Breeze
  • John Tripp
    John Tripp Jun 27, 2009
    Just as MAYTAG317 mentioned. The start relay and capacitor have issues with burning out. You can replace the parts. and give it a try. But if there is a problem with the compressor the problem will happen again. Testing the compressor for burnout. You will need to unplug and remember each connection you remove and be sure that they are replaced exactly as they were before testing. Behind the cover and with the start relay removed you need to check continuity or ohms between all three prongs two at a time. They are marked C=common R= run and S= start touch the probes to c&r then r&s & s&r again taking down the readings and any reading without a number or blank reading means open . After this touch one probe to each prong and the other to the copper pipeing ouside the compressor. any reading here indicates burnout. Hope this helps, Sea Breeze
  • John Tripp
    I will have a YouTube short movie soon showing how to test compressors. Stay informed , I let you know, Sea Breeze
  • 46 Answers
If you have a hermetic checker you can if not its just a chance replace over load if it good it will start
I have a maytag side by side refrigerator freezer with a Embarco EGY 100 HLP compressor
Probably not. Sounds like compressor would have to be replaced. It's an expensive repair. It would depend on age if unit
Oct 12, 2017 | Maytag Refrigerators
I have a GE side by side fridge that is not staying cold and everything in the freezer is mush. Any ideas what might be the problem? The fridge is only 5 or 6 yrs old.
yes I just repaired one yester day / park city utah .. it had a bad p c ( main board failure / i replaced the board and that got everything going but still no cool . in ching the overload on the compressor it had failed also . tes of compressor / it ok so i repl the overload relay and comp came on and it cked out a ok .. . h/o very happy as it didn't need a compressor .. **** hope this hepled mm feed back pls .
Jan 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Fan runs but copressor will not kick on
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Kenmore 53701 Dehumidifier
Compressor won't come on fan works find electric to comp
look at the capacitor to see if swelled up domed on top if so bad also look for burnt wires on the compressor
May 09, 2009 | Coleman Heating & Cooling
No cooling on eather side
No, white to com, black to the run terminal, and to the start through the capacitor. I suggest you also have a 15-amp fuse or breaker in the line for protection. Given that you say the relay, cutout, and cap check out, and you say there is continuity through the compressor, I have to think that there is a high-resistance connection in the circuit that feeds the compressor. Suspect bad connection at the thermostat or the defrost timer. Be careful, and work with one hand behind you back so you do not receive a dangerous shock.
Dec 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Freezer is not freezing...
2 possibilities one is a bad start relay on the comp or the comp could be bad. the relay is faily inexpensive and you should be able to replace it your self if the compressor is bad it will require a technician. good news is the refrig is under 5 yrs old and the compressor should be in warranty still
Dec 14, 2007 | Jenn-Air JFC2087HRP Side by Side...
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Kenmore 57029 Side by Side Refrigerator Logo
191 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
