Question about Whirlpool Duet GHW9150P Front Load Washer
Got code F02 after cleaning all drain system and replacing pump.
Hello.
Please help.
I have problem with my Whirpool Duet Front load washing machine. I got code F02. I did read almost of your advices, did all the cleaning works on the draining structures. Today, I just replace it with a brand new drain pump and still have the same problem. I ran it through the "drain-spin" cycle (11 minutes cycle ) it completed- well done-; then I ran it through the "rinse-spin" cycle (21 minutes cycle) it did well till last 6 minutes the machine stopped and flash F02 again.
Please advice me what to do next to fix the problem for my 5 years old machine. Thanks.
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Posted on Sep 29, 2010
Hello Im getting a code F2 what do Im using Ultra HE detergent. One time I added chlorine straight in the washer, bad idea and noticed since then it continues to show the code F2 often on with some...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Whirlpool GHW9400 Duet Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water will not drain the fo2 code is on which I know it means its clogged but how do I get it unclogged?
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stops with code F02
Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an error code that flashes F02
"F02" is a Long Drain error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The majority of the time, all you have to do to correct this problem is to clean out the drain pump reservoir or drain hoses. Follow the advice in the link provided. If all preliminary checks do not solve your problem, the manufacturer recommends replacing the drain pump. If you have questions, please let me know. I hope this helps you.
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pump humms but won't pump water out
It sounds like the pump motor or the impeller may be damaged. The "F02" error code is usually attributed to a pump failure or clog somewhere in the drain system. If you have made sure that the drain lines and pump reservoir are clean, and the pump still does not run properly, I would replace it. The first link explains the "F02" error and how to check the pump.
This second link explains how to replace the drain pump:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
A replacement pump can be found at searspartsdirect.com. Just type in your model number and the pump can be found under the "Pump and Motor Parts" heading as item number 10 (part #8181684). This is a simple repair. Just read through the instructions thoroughly before starting any repairs. If you need further assistance, please let me know. If you do not wish to purchase parts on line, use the part number provided and take to your nearest appliance parts retailer. I hope this is helpful to you.
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
242 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
