Question about Ovens
Need replacement temperature knob for Westinghouse Roaster Oven
IAny idea where to get one?
    President:
  • 1,136 Answers
Hi, If you get me a make/model#, I can look this up for you.
Vic
Posted on Jun 27, 2009
How do I turn on my Westinghouse 613 oven please?
Select the function on the far left knob. Select your temperature with the knob second from left. Select the cooking time with the knob to the far right.
Dec 24, 2017 | Ovens
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
We are renting a property with a Westinghouse mod 05-208307, never used it before, the setting have worn off around the oven nobs and don't know what they where pls help, can use over
The knob is the image of this link http://www.repairclinic.com/PartDetail/Knob-Dial-or-Button/5304441580/1063188 is pretty typical of all westinghouse knobs, that one shown is for westinghouse and perhaps can give you a good idea of the temp. set based on how far you turn it
Gene
Aug 13, 2011 | Ovens
The knob on the roaster oven was broke off, when we took it out of the box.
I would suggest that you contact the people who supplied you with the roaster, and ask for a replacement.
After all, it will be under guarantee.
Dec 19, 2010 | Ovens
I need an owner's manual for a very old Westinghouse roaster/oven my mom had that is at least 60 yrs old. I want to understand how to use it - not just for cooking a turkey. Please help me or tell me how...
This site has a Roaster Identification guide, and downloadable manuals for several different models. I just spent the better part of the day on the same search you were, and lucked across this one. I'm sure it'll solve your problem. Happy Holidays!
http://www.jitterbuzz.com/indroa.html#manu
Nov 19, 2010 | Ovens
Takes long to reach it's temperature
Hello there
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 09, 2010 | Fisher and Paykel OS302SS, Stainless Steel...
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
Gas self cleaning 30 range. In bake mode does not heat as hot as before, takes longer to bake items.
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Aug 14, 2009 | Ovens
    Need instruction manual for operating Indesit Automatic Oven
    I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
    Mar 02, 2009 | Ovens
    Ovens Logo
    220 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
