Question about Garden
I have a 314 john deere lawn mower with the motor running full throttle when you engage th blades the motor dies it has a electric clutch
4 Suggested Answers
  • 708 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
nova2nv
  • 197 Answers
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
Why mower blades will not engage when buttom is pulled
I believe this one has an electric clutch. Check to see that the switch is operating properly, that the wiring is good to the clutch, and that the clutch is good. Use a volt meter to check that there is voltage to the clutch when the switch is operated.
Jul 15, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Mower blades will not engage on my STX38
Turn the key switch to the on position. Pull the blade engagement switch on.Look under the engine and find the electric clutch. Disconnect the wire connection there and while using an ohm meter, check and see if there is 12 volts on one of the wires. If so, then the clutch may be your problem. If not, then you need to trace back the wire from the clutch connection and find out why there is no voltage
Sep 06, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
Stx 30 Starts, runs until attempt to engage electric clutch.Thanks
I have a John Deere STX30. I can start it, but when engage into gear it die completely!
Jul 06, 2011 | John Deere Lawn Tractor Seat F710 F725...
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Sep 09, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
