Question about Maytag Dryers
Replacing dryer belt
Need help replacing dryer belt, start to finish. Belt is still on.
  • 46 Answers
Your gona have fun not sure how old this is but ill try there is 2 screws in the front on the bottom take these out swing front out it has 2 clips at the top it will coime off as soon as you tip it far enough now you see the drum you must reach in and take the bel off the idler look at how it goes once that is off in the front inside you will find 1 screw on each side take these out lift top up now in the front you will find that the drum is held up by a bracet 2 big screws on eather side take these out and take off now the belt will come of just do it backwards you will be fine
Posted on Jun 27, 2009
Hi. I need help for replacing my dryer belt on a frigidaire mex731cfs. Please provide me with a step by step process, preferably with diagrams & pictures. Thanks!
http://www.ehow.com/how_6103112_replace-belt-frigidaire-dryer.html
here is a belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Mar 30, 2011 | Dryers
Not turning
Un plug the dryer and take the top off via the screws at the back.
Is the belt still round the drum?
If not belt needs replacing and the drum needs checking
If the belt is still in tact, then the capacitor may need replacing.which helps to start the drum. to test this replace the top and turn the dryer on is there a hum?
You will need an approved engineer to carry out more tests or repair
Sep 20, 2009 | Hotpoint Dryers
Replacing belt, can't seem to get belt tight. Need to know how to wrap belt around pulleys.
You can find the belt routing for your Maytag here:
http://www.repair-help.com/kb/index.php?article=105
If it won't tension, perhaps you have the wrong belt. The correct belt can be purchased from your local source or this website.
For those of you with other Brands of dryers start here:
http://www.repair-help.com/kb/index.php?category=13
Note: After unplugging dryer; The belts for most regular dryers are accessed by removing the front panel.
Wash and Dry and put the clothes line away!
Apr 25, 2009 | Dryers
Amana dryer Model leb107w2
It sounds like it needs a new belt. The smell is probably the rubber belt overheating because it's slipping. The belt tensioner may need adjusting or replacing as well.
Apr 21, 2009 | Dryers
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
How to replace the belt on an Indesit IS60V Tumble Dryer
hello, replacing a belt on a dryer is pretty straight forward and wont use to many tools other then what you need to take the cover off, the only difficult part is keeping the belt on the pulley while getting the belt all the way around the tumbler it may take a few trys but its not imposable when i did mine it took about 10 mins to get the belt on the tumbler while keeping the belt on the pulley if you have somebody that can help you this will make the job allot easier. good luck
Mar 26, 2009 | Dryers
How do I reset the belt tensioner on my dryer
there should be a screw for ajustment adjust the screw
Feb 12, 2009 | Amana DLE330RAW Electric Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Need Help replacing dryer belt
PUT BELT AROUND DRUM FIRST AND NOW YOU HAVE TO GET TO BACK OF DRYER ,SHOULD HAVE SMALL PANEL AND ISTALL FROM THAT SMALL REAR PANEL NOT EASY
Nov 29, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
