Question about Samsung AW0603B Air Conditioner
My window ac is not producing cold air, is it the freon?
Window ac is not working is it thefreon the fan works
I buy new window a c on august 7. but ac is not cold air,
Posted on Aug 20, 2009
    Problem Solver:
  • 17 Answers
Make sure your filter is clean.
Posted on Jun 27, 2009
How do I know if my fridge uses thefreon with the oil
most fridges are a sealed system from the factory, and are not able to be serviced. Generally most compressors require pag oil with freon. The freon in the transportation industry is R-134A with R-12 in older vehicles. Household have R-44 and R-22 in older appliances. There are a few different types of pag oil for each application.
Mar 24, 2013 | Refrigerators
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
The unit does not cool anymore. The fan works but the temp is in at 80.
IF THE FANS ARE WORKING ON BOTH SIDES HOT AND COLD AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK
Dec 26, 2010 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Air conditioning not too cold ??
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Let me explain in layman's terms how the air conditioning (AC) system works and what could be happening to your car.
Like your body, the air conditioning compressor is the heart of the AC system, and Freon is the blood. The compressor pumps Freon throughout the AC system, either the older type R12 which costs as much as gold it seems these days, or the new environmentally-friendly R134A Freon. This Freon is a gas and liquid combination that is compressed and circulated throughout the air conditioning system. The compressed Freon is pushed through the system under pressure and is passed through different sized metal and rubber hoses and a special valve called an expansion valve that cause the gas to expand and contract.
This expansion and contraction makes the Freon gas very cold. This cold gas makes its way via metal lines into the dash area of your vehicle to the evaporator core. This evaporator core is like a small radiator, except it has cold Freon circulating inside and not hot antifreeze. A small fan (the AC blower fan which you control from the control panel on the dash) sits in front of the evaporator core and blows air across this cold evaporator and then through the vents inside your vehicle.
The other objective of the air conditioning system is to remove the heat from inside the cab of the vehicle. This heat is removed by the Freon with the help of the AC condenser located at the front of the car (usually in front of the radiator). The Freon coming back from the evaporator carries the heat from the cab to the condenser via rubber and metal hoses. Just like your radiator, the condenser is lightweight aluminum with many internal winding coils.
The Freon travels through these coils, and in between these coils are small slits or fins that the Freon is forced through. The condenser will have an electric cooling fan mounted in front or behind it to push or pull air through these fins to remove the heat from the Freon. Some vehicles still use the old fashioned fan blade driven by the engine to pull air across the radiator and the condenser.
Now I know that is just a tidbit of information on how the air conditioning system works, and it is very general, but I wanted you to know what to look for to give you insight as to what might be happening with your vehicle.
A few causes of low cooling efficiency or no cooling at all at idle are:
Lack of air flow across the condenser. Make sure the electric cooling fan motor near the condenser is coming on, or in models that are equipped with a fan blade make sure this fan is turning and is turning very fast.
Low Freon levels. Freon level and pressure should be checked by your certified air conditioning mechanic.
Overheating. If the engine is running hot or overheating, it can have a noticeable negative affect on the air conditioning system. Some cars have two electric cooling fans, one for the air conditioning condenser and the other for the radiator. Make sure they are both working properly. Usually at idle on a hot day with the AC on both fans will be on.
When the vehicle is traveling at freeway speeds, the compressor is pumping the Freon throughout the system much faster and harder than at idle. There is a dramatic increase in air flow across the condenser due to 55 mph winds, and the engine is usually operating at a cooler, more efficient temperature as well, thus allowing the air conditioning system to operate efficiently.
Note: An air conditioning system that is somewhat low on Freon can still feel comfortable at freeway speeds due to the added air flow across the condenser which can overcome the ill effects of slightly low Freon. Periodic air conditioning performance checks by your mechanic are the best way to keep the system in great shape.
Hope this helps.
Goodluck
Oct 08, 2010 | 1998 Cadillac DeVille
My ac works inside, fan comes on and blows fine ,but outside fan wont kick on just makes buzzing noise and no cold air just air
Hi, normally when your freon is low, system won't work, look for filter dryer, follow high pressure tube from compressor to condenser, filter dryer normally have sight glass where you can see freon moving in system, if there's bubbles, you need freon, freon should be charge until glass get clears, hey remember to always charge from low or liquid side of system.
Aug 02, 2009 | Heating & Cooling
Ac system does not get cold
you should go to a mechanic and check the A/C if the freon id low it won't cool , some time at mornig it give you the semsation that is cooling but probably not..
Aug 01, 2009 | 1999 Volkswagen Cabrio
Air conditioning not working 100%
You may want to have the evaporator (the AC part under the dashboard on the passenger side) cleaned. It needs to be taken out and cleaned. Normally this would solve the issue. Have the freon checked if there is a decrease. You may have it filled up and have the system checked for leaks.
Jul 26, 2009 | 2004 Audi A4
1999 9.3 air blows hot
try the freon,best odds it is freon,but check that the ac cooling fan or fans are comiming on when compressor come s on
Jul 03, 2009 | 2001 Saab 9-3
Saturn ac wont blow cold air
check cooling fan operation while ac on.If fan is working proper,will probably have stuck exspantion valve.
Jun 18, 2009 | 2003 Saturn L-Series
Samsung AW0603B Air Conditioner Logo
442 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
