Question about Dometic Rooftop RV Air Conditioner
I have a heat pump Pengouin 630515-331C and i need the air distribution box with the knob control
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
The part number that you are looking for is 3106152.006. The is the complete non-ducted air distribution box for the upper unit that you currently have. You should be able to contact your local authorized dometic repair facility and have them order it for you.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 04, 2009
No heat. New thermastat, heater core flushed, good circulation. Has a rear heater.
Does blower motor work , air blowing out of ducts ?
Temperature blending is varied by the air temperature control door, which regulates the amount of air that flows through and/or around the heater core (18476) , where it is then mixed and distributed.
Movement of the control knob from COOL (Blue) to WARM (Red) causes a corresponding movement on the air temperature control door and determines the temperature that the system will maintain.
Temperature Control
The temperature control operates in the following manner:
  • Temperature control of the heater system is determined by the position of the temperature control knob (between COOL-BLUE and WARM-RED) of the heater control .
  • This control knob is connected to a potentiometer mounted in the heater control . This potentiometer is electrically connected to the electric blend door actuator that operates the A/C air temperature control door.
Feb 25, 2016 | 1996 Ford Windstar
1996 Honda accord cabin air control won't switch to full cold it's only warm air is it sticking in the air box or off track idk the knob won't turn all the way to cold either I force it and it clicks back...
the air control heat knob needs removing to determine if its the knob itself, this will just pull off, look at reverse of knod and look to see if the center locating pigot is worn "round" or broken , if this looks ok then the panel housing the knob controls will need removing and then check if the heat control wire is in place, if so trace this wire ,this is a bare steel control wire not an electrical wire, to the heater box lower dash behind the control panel and see if you can manually move the heat control flap this will look like two toothed semi circular cogs that inter lock , one may have jumped out of place try a little vaseline on the cogs to help lubricate the movement,this is just good practice, after all this i think you will have found the problem
May 04, 2014 | 1996 Honda Accord
1996 Honda accord cabin air temperature control switch won't turn to full cool mode sticking somewhere ac is cool not cold because heat is still coming threw where is the air flap sticking in the air box...
air control heat knob needs removing to determine if its the knob itself, this will just pull off, look at reverse of knod and look to see if the center locating pigot is worn "round" or broken , if this looks ok then the panel housing the knob controls will need removing and then check if the heat control wire is in place, if so trace this wire ,this is a bare steel control wire not an electrical the wire, to the heater box lower dash behind the control panel and see if you can manually move the heat control flap this will look like two toothed semi circular cogs that inter lock , one may have jumped out of place try a little vaseline on the cogs to help lubricate the movement,this is just good practice, after all this i think you will have found the problem.
May 04, 2014 | Cars & Trucks
Interior blower only blows up to warm on 1997 A4 2.7ltr
Check the blend door cable for proper attachment to the control panel and to the blend door. Try opening the door manually to see the you can get hot air out. If not, the door may be broken inside the heater box. If yes, correct/adjust the cable attachment for proper operation.
REMOVAL & INSTALLATION
1990-97 Passat Models
Install the cable ends marked with a white or blue band to the control head assembly. The cables must be attached to the control head before connection to the system air flaps.
  1. Remove the climate control head from the center dash assembly to access the control head cable ends.
  2. Remove the lower dash panels as necessary to access the cable lever arms.
  3. Attach the airflow distribution cable (cable 2) to the airflow distribution knob's lower control lever.
This cable can be identified as follows:
Operates the mode/central air flap Cable has a black sleeve and is 25.0 inches (634 mm) long Cable is marked with a white band
  1. Press the cable's sleeve against the control head stop and install the retaining clip.
  2. Attach the temperature control/air blend cable (cable 3) to the air temperature knob's control lever.
Operates the temperature control/air blend cable air flap Cable has a blue sleeve and is 21.0 inches (535 mm) long Cable is marked with a white band
  2. Attach the airflow distribution cable (cable 1) to the airflow distribution knob's upper control lever.
Operates the footwell/defroster air flap Cable has a black sleeve and is 37.5 inches (954 mm) long Cable is marked with a blue band
  1. Install the cable such that the blue band is over the retaining clip mount and install the retaining clip directly over the blue band.
  2. Install the climate control head.
  3. Set the air flow distribution knob to defrost.
  4. Connect the longest airflow cable (cable 1) to the footwell/defroster flap lever on the heater's air box.
  5. Press and hold the flap's lever toward the retaining clamp perch and install the cable retaining clip.
  6. Set the airflow distribution knob to the Vent position.
  7. Connect the short airflow cable (cable 2) to the central/mode flap's lever.
  8. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of both air flaps making sure they can be heard contacting their stops.
  9. Set the temperature control knob to full cold.
  10. Connect the blue-sleeved cable (cable 3) to the air blend/temperature flap's lever.
  11. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of the air blend/temperature flap making sure it can be heard contacting the stops.
Fig. Side view of the control head and cable location. 1. Footwell/defrost flap cable-2. Air distribution cable-3. Temperature control flap cable
Fig. Temperature flap cable location and adjustment
Nov 24, 2011 | 1998 Audi A4
I have a 2002 Nissan Sentra the thermostat opens, changed water pump. the heater still blows cold air .
you may have a problem with heater box. your air/mix door may have an issue. feel the knobs on the control unit. if the cold/heat know feels kinda funny from the other knobs, then thare is a problem with heater box/cables??
Sep 10, 2011 | 2005 Nissan Sentra
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
Apr 06, 2011 | 2000 Ford Explorer
Control knob for heat/cold air only works on high
usually it is the fan speed resistor in the air box, I had the same problem with my wife's 2003 stratus sxt. I found that the resistor, that is what I call it, had broken a soldering point. The fan will only run on high if this piece is broken or burned out. It is in the air box usually near the blower motor behind the glove box. Generally has two or three small screws holdin it in
Jul 17, 2010 | 2003 Dodge Stratus
I have a 93 Saab and my vents aren't blowing heat. When I hit a bump in the road it may kick my heat on full blast for a couple of minutes, but as soon as I hit another bump, the heat kicks off. Also, the...
You don't say whether the fan starts and shuts off with the bumps, or the heat goes cold but the fan stays on. If it's the fan shutting off and coming back, you most likely have an intermittent connection to the blower motor somewhere at the fuse box, the fan speed control switch or the fan motor, or a loose ground connection at the fan motor. The fan motor is visible under the right side speaker grille on the dash. Make sure you re-connect the short black corrugated hose to the grill vent or you won't have defrosting on that side!
The air distribution rotary switch controls where the air goes. The fan speed switch controls exactly that: fan speed. the temp rotary switch controls the coolant temp into the heater core. You need to clarify what you mean by "Also, the dash controls for the vents won't allow me to turn up the power"
You might also have one or more of the following issues:
  1. is you vacuum tank properly connected and are there no leaks in the vacuum piping? The tank is in the driver side rear wheel well below the trunk deck on a convertible, and in the passenger side front fender area on the other cars. It's a white bottle with one or two hoses connected to it. If not properly on, your vacuum operated heater flaps won't move. Does the air distribution knob make sucking or hissing noises when you set it to different positions? If not, check the tank connections, look for vacuum line leaks, then suspect the vacuum valve behind the distribution knob.
  2. if the air distribution rotary switch makes noises when you change its setting, but nothing happens, then suspect the vacuum solenoids that open and close the heater flaps - could be a loose vacuum line or a defective vacuum solenoid
  3. the shaft connecting the temp control knob to the heater valve behind it may not be properly in place. This can be inspected, and adjusted if necessary, from the left side speaker/vent cutout on top of the dash. Make sure you re-connect the black flex hose to the air vent tube, or you'll get no defrosting afterwards!
  4. remember, the centre vents always blow cold air; a brilliant idea from Saab so the driver (and passenger) can get fresh air in the face and stay awake while the rest of the driver, passenger and car is toasty!
Oct 26, 2009 | 1993 Saab 900
Hot air forced into cabin while driving 92 saab 900
the air distribution switch controls the air distribution and the fan, distribution switch in the 0 (straight down position) will be off. Car movement forces air into teh body, but with teh fan off there will be no air when the car stops. Does the fan run when the distribution switch is in any other position? it should respond to the speed settings of the fan switch.
There is a vacuum bottle accumulator that assists the distribution switch, sometimes this gets disconnected and the switch settings don't work.
Do you hear any noises if you turn the distribution knob while the car is running? suction noises, or flaps opening?
If not, then you likely have a vacuum problem (check for a white bottle in left front wheel housing, except convertible -> under the spare wheel, tank should have one or two vacuum lines connected to it (one for convertible). A disconnected or leaky line is the most likely cause.
Possible other causes are faulty air distribution switch; burned out fan motor; inoperative vacuum solenoid motors controlling air distribution flaps.
But check the vacuum accumulator first, if under the spare wheel, the lines are easily dislodged.
May 30, 2009 | 1993 Saab 900
I have the same problem with my windstar blower is fine but is coming cold air but no heat i dont know what to do can any one show me how to fix it thnx
First, feel the heater hoses going into the firewall under the hood. If they are hot, then you have hot engine coolant going into the heater core. If they are not hot, then you either have a bad thermostat or you are very low on engine coolant.
Next you need air flowing through the heater core so it can come out heated through your vents. If the iar is flowing somewhere else, your temp blend door is not moving because the bend door motor is bad or your temp knob on your heater controls is bad. The blend door motor is an electric motor.
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
Temperature Control
  • Movement of the control knob from COOL (Blue) to WARM (Red) causes a corresponding movement on the air temperature control door and determines the temperature that the system will maintain.
System uses a reheat method to provide conditioned air to the passenger compartment.
  • All airflow from the blower motor (18527) passes through the A/C evaporator housing .
  • Temperature is then regulated by reheating a portion of the air and blending it with the remaining cool air to the desired temperature.
  • Temperature blending is varied by the air temperature control door, which regulates the amount of air that flows through and/or around the heater core (18476) , where it is then mixed and distributed.
inside you plenum box:
Mar 03, 2009 | 1998 Ford Windstar
Dometic Rooftop RV Air Conditioner Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
