Question about Canon PIXMA MP600 all-In-One InkJet Printer
Have Vista on notebook. I have a Canon mp600 hooked to my Dell Desktop PC. Using Verizon Fios router for my wireless connection I cannot get printer via the notebook to work. Use MS network wizard and setup instructions.
    Scholar:
  • 92 Answers
Here is a link to the support page for your printer. I read through the documentation for the MP600 and did not find anything saying you could print through the network. What I mean is there is not a ethernet port or a wireless interface to connect your printer to your network. There is a wireless feature where you can beam photos from your phone. I think you may be confusing this with being able to print from your computer wirelessley.
Posted on Jun 27, 2009
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
I have a Canon with a USB connection. Can I connect this to a Ethernet connection on my wireless router? (I had it working thru USB port of apple airport router, but new Verizon FIOS wireless router does...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
dont forget to vote
Feb 27, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Is there any advantage using my DLink DIR625 with my Verizon 9100EM modem/router set up using WPA2? I have one ethernet tethered desktop and one laptop, plus using an wireless Skype Ipevo phone on the...
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
Jun 27, 2009 | Computers & Internet
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
FIOS Internet connectivity problem with Toshiba Satellite 105
Is your laptop running Vista and the desktops running Windows XP or they all running the same software??? Also your problem is the fios router they come set up to be on a automatic channel search so there always searching for the best channel and you probably live in a brick house....Go to the settings for the router you can get to them easy with the software they downloaded to your computer its the fios help icon on your desktop and you can change the routers channel go to 7 or 11... If you have any questions just let me know also please rate me if you get a chance..
Thanks,
Steve
Dec 17, 2008 | Toshiba Satellite A135-S2246 Notebook
Link notebook and desktop pc's both at home and office capable of sharing a printer located at office.
what are you using to configure the wireless????
the process is simple and yet it is complecated to have both wireless configuration.
let me know if you need directions and step-by step.
frcs68@hotmail.com
Oct 17, 2008 | Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Canon PIXMA MP600 all-In-One InkJet Printer Logo
299 people viewed this question
old marine
old marine
