Question about Toshiba Satellite Pro L300 Notebook
I cannot set up my existing broadband connection in vista
Hi There, I have an Aspire 5610/ BL50 running on Vista. Im having problem connecting to a 3 broadband dongle. Its showing 5 blue bars signal strength but failing to connect. When I use it on another...
you should check the set APN on the vista pc. or if settings are inserted by default, simply uninstall and reinstall the 3 broadband dongle. if problem persists, and you are sure it has worked before, do system restore to a date you think connection was ok. malware or virus may cause modems to fail initializing connection.
thanks for using fixya.
Aug 24, 2011 | Acer Aspire 5610 Notebook
I am using windows XP in my Toshiba laptop sattellie Series. I am unable to make any new connection to connect to Internet.
That is because the L300 does not support XP.
If you reinstall Vista, all will be well again.
XP is no longer supported even by Microsoft as it is over 10 years old and now obsolete.
Hope that helps.
Jan 23, 2011 | Toshiba Satellite Pro L300 Notebook
Please what is the steps for correcting my wireless printing, my vista/laptop cannot see my printer to print wirelessly any more I have an hp 6310 all in one. There is another computer in the house that...
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system’s networking wizard. If not, then the network must first be established, only then the printer will be made available through that network. get more information and help for Wireless Printer Configuration .
Apr 15, 2010 | HP Officejet 6310 All-In-One InkJet...
Connecting to my existing network at home.
What type of wireless station do you have? Have you tried to connect the wireless station with another computer? Feel free to visit digitalsupporttech for getting help.
Aug 25, 2009 | ASUS Eee PC 701 Notebook
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Doesn't work with windows vista
1. check if there are lights on the specific router port where you have connected the Vista (e.g. if it is on port 2, check if there are lights on #2 at the front panel of the router).
2. check the ip address by going to command prompt (click start-run-type cmd press enter. on the command prompt, type ipconfig/all)
3. ip address should be similar to what your Windows XP is getting. Subnet mask, gateway, and DNS servers should be identical.
Eg. If XP has a 192.168.1.100 IP, your Vista should have 192.168.1.x IP address where x is a variable number other than 100.
4. If your IP address, subnet mask, default gateway, and DNS seems aligned for both PCs, check your browser settings. Open IE, go to tools, internet options, network connection and make sure that never dial a connection is selected.
Jan 16, 2009 | Microsoft Broadband Networking MN-500...
Dial up (3g dongle) internet (lan) sharing on vista
the ps network will not recognize dial up.. you need to update to broadband... sorry
please rate me...thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
I didnt understand the solution for the router not working on vista
Try hitting <Fn> + <F2> keys on keyboard. If that doesn;t work click Start > Run > type devmgmt.msc > check device manager for your wireless adapter properties --- is it working properly?
Jun 26, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Broadband connection problem
Best way to buy:
Usb Ethernet Adapter.
Otherwise, in that case it need Usb cable drivers to be installed in PC..... then u have to make share this Usb network connection(in network neighbourhood........network connection).
parrallel cat5 or cat6 cable should connect u'r PC to Router.
Dec 27, 2007 | Microsoft Office Outlook 2003 for PC
Wireless set up for ntl
hey thats easy man dont worry, if you have a existing broadband at home, just connect the broadband to your router, then connect the cable that comes up with the router to your laptop. then access the web configuration of the router, the ip address is usually written in the manual. then configure it with the settings that your Internet Service Provider gave you to connect. then configure the wireless settings and your done... if you still have problems, please feel free to contact me again..........
May 11, 2007 | 2wire (1000-400108-001) Router
Toshiba Satellite Pro L300 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
