Question about Singer CE-100 Futura Computerized Sewing Machine
Button hole I have done everything the manual says step by step yet I continue to get the flashing light. I have a baby shower gift I am trying to finish tonight for tomorrow and can't beccause I don't have button holes! This machine continues to frustrate me. My old SingerI had for 20 plus years was easy to run.
I worked for two hours and kept getting terrible button holes.. the back side has loose thread while the front looks OK. I finally went back to my 30 year old Bernina to complete the button holes....
Does anyone know how to fix this problem?
Posted on Feb 10, 2010
How do i make an x follow the oncreen progress of sewing a single run quilting pattern
Pantograph - IntelliQuilter® ' Computerized Quilting ...
www.intelliquilter.com/iQpedia/Pantograph.php
A pantograph pattern is one that goes from edge to edge, over the entire quilt ...patterns - there are some interesting combinations you can use to create ... Remember to align the on-screen quilt to the quilt on the machine before you sew (use the ...Touch Realign, and follow the on-screen prompts: Find a reference point on ...
Baby Lock: Ellure
babylock.com/sewing/ellure/
With a 5" X 7" embroidery hoop and a wide variety of built-in stitches and designs, ...With 120 frame patterns and a large library of built-in designs (including 40 ... cover so you see your progress and avoid running out of thread mid-stitch. ... Baby Lock IQ Technology is what makes Baby Lock machines so smart and efficient.
[PDF]Quilt Magician Manual updated 4-23-12.indd - TinLizzie18
tinlizzie18.com/images/Quilt-Magician-Manual-updated-4-23-12.pdf
This manual will cover everything you will need to know to RUN your Quilt ... Let's getto know your Quilt Magicianâ„¢... .... pattern boxes at one time, the system will onlyrun the pat- ... You can have as many patterns as you like in each pattern box. Circle for. Start. (X) for ... button and follow the on screen steps to re-calibrate.
[PDF]SideSaddle (SS) Users Manual - The Quilting Solution
Jan 11, 2016 | Sewing Machines
My Janome Memory Craft 5700 using the R buttonhole foot will only do a striaght line will not turn at top for bartack any suggestios?
Go to page 25 in your 5700 manual and read from the beginning about how to set the buttonhole foot up. Make sure you have followed all steps. There is a lever on the button hole foot that you pull down. If you have done everything correctly, then you may need to call a service tech at a sewing store and have it serviced. You can get a copy of the manual from Janome's website.
Hope you find the answer.
Aug 08, 2015 | Janome Sewing Machines
My memory craft 300 will not button hole properly.It will not go backwards after it has done its first lot of stitching
Check your manual you might have to push the reverse button a lot of machines you have to do the button hole manually.
Jul 26, 2014 | Janome Memory Craft 3000
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
I'm trying to make a button hole and have tried at least 8 times. I've done it step by step according to the manual but the material seems to stay in one place, balls up until the thread breaks....
check the feed dogs & see if they are up--page 51
did you pull down the buttonhole lever---page 38
check the tension to make sure it correct-what the manual shows
check to make sure the thread has not come off the thread take up lever--page 16-- number 6
also clean under the needle plate & in the bobbin area for loose threads or lint
also check the needle--page 53
Aug 11, 2011 | Singer 4423 Sewing Machine
One step buttonhole help!!
On my machines, the one step button hole requires a pull down sensor that the button hole foot triggers when it has done one side. You put the button in the holder part of the button hole foot, set up with sensor and start to sew, being careful not to touch the trigger, then the machine will sew the required length, change stitch and then do other side. Maybe there's a demo on you tube ? I hope this helps
Sep 04, 2010 | Janome Sewist 525S Mechanical Sewing...
Button hole function won't get past step one
I have been working on this for the last 2 hours myself....Can't get past step one!
Tried all button hole functions too...even pulled out the book....no luck yet.
Kim
May 21, 2009 | Janome Memory Craft 3000
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Janome JD1818 Automatic Buttonhole Not Working
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Mar 16, 2008 | Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
117 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
