Question about Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 Will Not Advance / Black in Viewfinder.
My Canon AE-1 Program will not advance. I replaced the battery, and tested it and it's good. However, when I look through the viewfinder it's all black. Also when I hold down the shutter release, the lights/numbers on the side do not pop up. The mirror is at an angle. Any ideas on how I can fix this on my own?
cammedic
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
  • 302 Answers
SOURCE: can't see through viewfinder (it's all black) and
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Posted on Oct 11, 2009
  • 571 Answers
SOURCE: I have an Canon AE-1 and the film advance lever
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Posted on Dec 05, 2009
cammedic
  • 667 Answers
SOURCE: I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Posted on Jan 04, 2010
Obertelli
  • 3006 Answers
SOURCE: the mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Posted on Feb 13, 2010
Testimonial: "ha ha yes that's what it was thankyou!"
Hi I have a canon ae-1 but the mirror stays latched up and the film will not advance and when I look through the shutter it is black.
The mirror has most likely locked up due to the battery being dead. Replace the battery and the mirror should drop down and the shutter will work again.
Feb 16, 2011 | Canon F1-N 35mm SLR Camera
My shutter release button is not working, instead the shutter is being released when I use the film advance lever.
Your camera has a bad magnet in the body.
Repairs will cost more than probably what you paid for it; I'd suggest getting a replacement (I got a Canon AE-1 Program for $40 on craigslist, ebay has good prices)
Nov 11, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 SLR film Advance lever does not work
Mechanical problem that must be repaired by a technician. It may be time to retire this camera.
Oct 04, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1 program camera
I suggest trying a new battery 1st
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 with Program
Have you change with a new battery?
Or check the battery with a DVM(digital volt meter).
Or get some batteries and connect in series to equal to that voltage and use two wire leads. One lead to -negative side of the battery, other lead to +positive. Now, -neg to neg of camera and +pos to pos of camera.
You now have power to the camera to test. This will save money rather than buying the camera's battery for testing. AA, C or D will work, just look on the camera's battery to see the right voltage.
Examples: with two batteries (1.5VDC + 1.5VDC = 3..0VDC). So -(negative) of one battery to + (positive) of the second battery with solder.
-(-neg, battery, pos+) solder to -(neg, 2nd battery, pos+)+
left side , use black wire on -(Neg) and solder
right side, use red wire on +(Pos) and solder.
Now you have two leads, use those to connect to camera.
Do you get data from viewfinder?
Dec 10, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
134 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
