Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater Logo
A
Anonymous Posted on Jun 19, 2014
Hs error code what does it mean? - Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater
Robco Water
Level 2:
Champion:
  • Hayward Expert 258 Answers
  • Posted on Aug 12, 2014
Robco Water
Hayward Expert
Level 2:
Champion:
Answers
258
Questions
0
Helped
152527
Points
337
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
1helpful
Lg dryer model# DLEY1201V what does error code HS mean?
Humidity sensor error code. Clean humidity bars below filter housing on inside of dryer.
Aug 15, 2017 • LG Dryers
We a "service" message on our Hayward gas heater h250fnd also error message HS or H5
the code is HS. it means that the maximum allowed temperature has been reached too fast. there are a few situations that may cause this. restricted flow is the most common
I have a LG dryer model DLE5932W with a error code of HE
I'm sure you have fix the situation by now, but could the error code be a "HS" and not a HE? HS is a humidity sensor issue. often the metal strips below the filter on the inside of the drum are coated with fabric softener and cause issues. clean them with goof off or denatured alcohol will often fix issue. sometimes(rarely) one of the connectors comes off and causes errors. if you are still having issue, post a picture of the error code as a comment to your original post.
Aug 31, 2016 • LG Dryers
My Hayward H400FD is showing a H5 or HS error code, what does this mean, and what do i need to replace?
HS represents a problem with the temperature being too high. (maximum return water temp exceeded). this can be caused by a restriction in the plumbing system. i have that problem when i start my pool after a cold night. the water temperature rises too fast and the heater protects itself by flashing that code and turning off. reset the power to unit and it should work ok. if not, you may have to dig deeper as to why this code is being generated
What does this mean Hayward pool heater h150FDN gives us an hs or h5 error?
HS = High Limit Sensor
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is: hs, not h5
2helpful
Hotpoint ultima washing machine has error code f-12
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
If this helps please rate me
I have a KM-1820 and the problem is CF223 error.
Meaning Motor error in the option bulk paper stacker HS-8E. Suggested causes Defective harness (S02400) between engine board and option unit interface connector. ? Defective option bulk paper stacker HS Corrective action Replace engine board Replace harness
Error code E4 on Mitsubishi HS-U576 VCR. Machine is eating tapes.
Hi, The error E4 means Reel Lock Detection.
Thanks! mannu_rakesh
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
