Question about Brinkmann Stainless Steel All-In-One Gas and Charcoal Smoker/Grill/Fryer 810-5100-0
Instructions on how to put a brinkman gas grill
Where can i find online instructions on how to put a brinkman gas grill pro series 810-9415-w together? It didn't have the instructions enclosed.
    Problem Solver:
  • 14 Answers
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Posted on May 30, 2010
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
I am trying to light a Brinkman Pro Series 8300 with no luck. I have never lit a grill before. Am I supposed to open a valve or something on top of the bottle of propane before trying to light the...
With all knobs on the panel to off, make sure that the hose going to the propane bottle is securely attached. Then open the valve on the bottle fully, and then shut it 1/4 turn from full open (this is called backseating a valve and is a good idea for almost all valves that you would operate, ie the water valve on the house). With a mild soapy water solution check the hose connection to the tank does not leak. It will make large obvious bubbles if you have a leak. Now go lift the lid for starting the burners. With lid open, turn the know to high and use the starter, for my grill I do that by pushing the knob in to operate the peizo igniter, but you could use one of those long nose lighters, like aim-n-flame. Start the burners you want to use all the same way and close the lid for it to reach full temperature, like around 575F I think (been a long time since I checked), but the temperature needle will stop moving up.
I hope this helps you get grillin'!
Aug 11, 2011 | Garden
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
Just purchased new Brinkman 5 burner Pro series. Worked fine when I tested it but now the main burner is the only one that will ignite and it won't stay on. The side burner works great.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Jun 19, 2011 | Brinkmann ProSeries 810-6330-W Grill
I threw the brinkman pro-series 810-8535-sb manual away by mistake. Can I print one via online?
I don't see a 810-8535-sb manual online. However, you can get the manuals for other Brinkmann Pro-series grills from their website: http://www.brinkmann.net/my_grill.aspx . The 4 burner 810-8533-S seems like the closest match. The direct link for this manual is: http://images.brinkmann.net/docs/pdf/810-8533-S.pdf . If you wait a while, the manual for the 810-3535-sb may become available through the My Grill site.
I hope this helps.
Apr 19, 2011 | Garden
I am trying to order a brinkmann pro series 2600 owners manual, i also need a list of parts for this grill, and i cannot find the link i need to do so.
Brinkman pro 2600 parts and manual issue.Follow my advice,I already did the research.Click on to Brinkman website, plug in your model # and you can download in PDF the original owners manual for free.Secondly call them and leave your phone number for return call.You will find most of your parts even though they are not listed on website and cheaper than after market sites.
Apr 11, 2011 | Garden
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 | Grilling
Where does the battery in a brinkman pro series 9415 go?
Whereas I can't help you with the exact problem as I am unfamiliar with this model, you can write, call or email Brinkmann's Customer Service where they can point you in the direction of where to download the instruction manual you need. Shouldn't be hard at all.
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
Aug 09, 2009 | Brinkmann All-In-One Gas and Charcoal...
No user instructions for brinkman smoker
May I get the make and model # to help you more
Jul 03, 2009 | Brinkmann Smoke 'n Grill Double-Grill...
Brinkmann Stainless Steel All-In-One Gas and Charcoal Smoker/Grill/Fryer 810-5100-0 Logo
259 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
