I have an older ac roof top unit (1988) its made by Coleman. When you first turn on the unit as long as it is cool, it will run for about five minuets on the low speed cycle (very cold), if you switch it to high cool it will run for about one to two minuets then it will trip the house breaker (20amps), not the couch breaker (30amps). I replaced the start cap, motor cap and another unnamed cap. The only things left in the system are a start relay and a thermal cut off switch which sits on top of the compressor, I bypassed this switch to see if it was the problem, but it still trips the breaker. I'm lost from this point and any help would be great
  • 50 Answers
Take a current reading on the compressor and the fan motors to see witch one is pulling the high current.
Posted on Jun 27, 2009
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
Feb 09, 2017 | Coleman Heating & Cooling
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
My roof top unit is letting the condensation run into the coach.
Either you need to replace the square gasket between the ac and the roof or you need to seal/replace your roof..
Aug 03, 2010 | Coleman Mach III Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
My a/c is leaking from the ceiling of the rv. i cant tell exactly where, but something isnt draining properly. does anyone have a clue as to what i can do about this? my rv is a 1989 model. the a/c is cold...
Look between roof & base of AC unit for little round button like pieces sticking down, which are drains, that have holes in sides that get plugged up. poking with a piece of wire or similar in that hole may unplug it. You should see at least 2. Depending on what type of AC unit, it may just be holes in base for drainage, but if necessary to unplug, you can easily remove cover. Coleman has 4 big Philips screws on top to remove & dometic has a bunch of Philips screws around lower edge to remove & cover will come off, to check where plugged. Make sure power is off inside.(breaker) You should see a trail of water across roof from AC when running & cooling, if not plugged. There is the posibility of a cracked drainage tray allowing water to leak inside as well on some of the older models. You should be able to inspect all of that when cover is off on roof. P.S. CAREFUL! Observe before lifting cover off for wasps in the area, as not unusual for them to make nests under cover. Be prepared, or do on cloudy day, early in the morning, or near sundown when less active. Also, if dew on roof, could be slippery.
Jul 07, 2009 | Heating & Cooling
Drain for a colelam rv air conditioer
It is entirely possible that a five minute test would not produce any noticeable amount of water. Turn off everything in the house that is using electricity and your 20 AMP service will be sufficient to run your AC.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
