Tub keeps filling with water-overflowing. - Washing Machines
    Problem Solver:
  • 16 Answers
Your water level switch is bad , you can usually pick one up at a used appliance store for about 20 bucks
Posted on Jun 27, 2009
Washer keep filling with water and will not kick over to next cycle mode for wash or spinning cycle on cold water?
Hello, Assuming the washer doesn't keep filling to the point it is overflowing the tub, it sounds like you have a bad lid switch. If it is overflowing then you may need a pressure switch or more likely the pressure switch tube (surgical tube) is just clogged where it connects to the outer tub. You can go to - http://www.searspartsdirect.com/partsdirect/index.action - Type in your model number then select model search. You can get part breakdown and buy parts for most brands. Good Luck.
Mar 12, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
I HAVE A GE WASHER MODEL WHDSR209DOWW THAT THE WATER OVERFLOWS. HAVE REPLACED THE WATER LEVEL SHUTOFF VALVE BUT IT DID NOT HELP! AT FIRST, IT OVERLOWED ON LARGE LOADS. NOW IT JUST KEEPS FILLING TILL IT...
Check and see if the hose connected to the fill valve and the tub is stoped up you could try blowing in it from the fill valve side to the tub . Hope this helps.
Sep 30, 2009 | GE Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
Washer overflowing from the tub
There's an air tube connected to the back of the water level switch, If that is kinked/pinched/crimped/disconnected or has a hole in it... the pressure switch will "think" there's no water in the tub and thus continue to fill it. Access your control panel and verify your air tube connection @ the level switch.
Aug 09, 2007 | Frigidaire FWS845GF
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
