Question about Maytag Atlantis MAV6000 Top Load Washer
How do you loosen & tighten the hoses
The Maytag Atlantis has a very narrow slot for the hoses. It's almost impossible to loosen or tighten. Any ideas on how to make this easier?
  • 46 Answers
Try using chanellock plyers works good you just have to take your time
Posted on Jun 27, 2009
Im having problem tightening the hoses to to maytag atlantis washing machine there is not enough room to use a regular wrench
You need to use what we call a pump pliers...
With this you can get in there and get the hoses tight.
You can find them at any Lowes, HD or local hardware...
heatman101
Oct 16, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Changing fill hoses---the connection to the washer is very narrow
Are the rubber gaskets in place on the hoses? Some hoses come with rubber gaskets others do not and they have to be inserted.
Jun 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Sep 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis
Usually you will encounter a situation where a wire will burn off and in so doing, it may trip a breaker,(turn it off then back on to be certain), or if fused, it may blow a 30 amp glass fuse or 30 amp cartridge fuse. Replace both tho eliminate any doubt. If all checks ok, disconnect the dryer from the power source and go internal to find the problem. Below is a popular link to provide you with more assistance, should you need it.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Jun 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
