Question about Ryobi Garden
Remove shaft to replace recoil on ryobi c530 trimmer
Ryobi c530 curved shaft trimmer, i need to remove the shaft drive to get the cover off to replace the recoil starter. the pull rope broke.
  • 109 Answers
SOURCE: just tried starting my ryobi trimmer and the
if ti didnt retract chances are the spring is broken and will need to be replaced
Posted on Aug 23, 2009
FreeTech
  • 426 Answers
SOURCE: replace pull rope
there should be a retaining C Clip that will need to be removed from the shaft look closely!
Posted on May 23, 2010
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
  • 316 Answers
SOURCE: ryobi ry34000 Starter rope will not recoil
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. gtui
Posted on Feb 19, 2012
SOURCE: starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Posted on Oct 17, 2012
31cc 700r curved shaft string trimmer binding flywheel and cord rewind during reassembly
as you put it together, pull the handle a bit so the recoil starter fingers fit into the flywheel as they should
Aug 18, 2015 | Ryobi Garden
I have a Ryobi Expand-It 2 Cycle 26cc Trimmer , and when i attacthed the pole trimmer and tried to start it the pull cord won't retract.. do you know how to fix this? i can't get the cover off
the ryobi expand-it is just a power head ( motor ) that you can attach any ryobi or like attachment to
There is no reason why attaching a pole trimmer would affect the recoil of the starter rope as it just slides onto the drive at the end of the shaft
the fix will require the removal of the cover and the tool will be in a selection of bits that you can get from a good tool shop or auto parts shop
from memory it is a 6 point star around 3mm in size
the failure to recoil is normally a broken coil spring
Oct 30, 2017 | Garden
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Removing the clutch from my ryobi weed wacker to replace/repair the recoil spring
remove spark plug put a piece of rope in hole to stop piston from moving there is a torx screw in center of clutch bell where drive shaft would go re move screw to remove bell use large channel locks or brass hammer to remove clutch assm still with rope in spark plug hole hope this helps
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
Dec 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you put a new pull cord on?
With great difficulty on that machine!!!
Its a "Half Cranked" engine (which is cheap and nasty) meaing the recoil / pull cord is located between the shaft of the brushcutter and the engine (NOT on top of the engine like proper "Full Cranked" engines are).
You will have to remove the engine to do this and probably loose the will to live in the process! Bin it and buy a Stihl bent shaft trimmer instead
Oct 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Lost manuel Can't start my Ryobi C530 gas trimmer
trun the on/off switch on,prime it with the bulb 3-6 times choke it , pull the cord 1 or2 times then take the choke off and pull a few times till it starts if it doesnt start you have problems.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
302 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
