Question about Kenmore 22422 Top Load Washer
Kenmore series 70 tip loader washer is leaking
Kenmore series 70 top loader washer is leaking water at bottom when it is off. It is washing fine.
  • 46 Answers
Your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Posted on Jun 27, 2009
Kenmore 70 Series Top Loading Washer Leaks
If this is a Kenmore TOP LOADER, you need to remove the exterior cabinet in order to access the washer interior and sufficiently inspect to determine where your leak may be coming from. This is much easier than it sounds. The following link explains how:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link provided and make sure you inspect all hoses and tub seals as well. This is a very simple repair that you can perform without the assistance of a repairman. The average cost of a pump is about $35.
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid), so I can determine what washer configuration you have. I hope you find this information helpful.
Apr 22, 2010 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore70 series washer 110.26752502 leaks water while filling
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
Replacement parts (if required) may be purchased on line at any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. The choice is yours if you wish to pursue this repair on your own. In my opinion, you don't need a "certified repairman" to find the source of a leak in most cases. Many of these repairs are simple with a little guidance. I hope this help you.
Feb 11, 2010 | Kenmore 22422 Top Load Washer
Kenmore series 70 squealing and leaking water
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Dec 11, 2009 | Kenmore 22422 Top Load Washer
How do I remove the pump from a kenmore 70 washer?
The Kenmore 70 series is a top loading washing machine. Different from the picture you have this listed under. If this is a Kenmore top loader, the following link explains how to replace the water pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this is a front loading Kenmore, the next link applies:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water is coming out of the bottom of the washing machine
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Nov 22, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
421 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
