Question about Toshiba Satellite 1805-S274 Notebook
Was given a Toshiba Satellite 1805-S274. It was missing a power cord. Have a universal cord. Computer comes up it seems but monitor is black. No instructions.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Does the computer appear to bootup and the hard disk light is flickering?
  • DigidocTN
    DigidocTN May 11, 2010
    What happens when you use an external monitor? Have you tried opening and closing the lid? There is a switch in there that may be stuck.
I turn on the power on my satellite 1805 and my screen comes on 1 at of 10 times ?
because it's old sorry. this is just the way of many laptops. the only "light" in the tunnel is that it may be repairable and it might even be relatively cheap ($100 U.S.) but you will have to check the yellow pages and/or the news paper etc to find the guys that do it because the big computer stores will charge you ALOT more. hope this helps and good luck:)
Jul 28, 2011 | Toshiba Satellite 1805-S274 Notebook
White Screen - Unable to See Desktop GUI.
Two separate problems, sounded like..
White screen? If external video is okay then it's likely (1) a bad screen, or (2) a disconnected video cable.
If the system shuts down, I'd check the fan - if the fan is reasonably clean and running, then it's probably a bad motherboard.
Mar 15, 2010 | Toshiba Satellite 1805-S274 Notebook
I required Toshiba Satellite 1805-S274 video graphic driver
Found it...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=128927&rpn=PS183U&modelFilter=1805-S274&selCategory=3&selFamily=1073768663
Oct 19, 2009 | Toshiba Satellite 1805-S274 Notebook
Vga controler for toshiba satellite 1800 s274
Hello, do you know the grafics card that you have on your Toshiba? Brand, model...? Regards
Jun 11, 2009 | Toshiba Satellite 1805-S274 Notebook
Need to change cmos battery for toshiba laptop 1805-s274
look on back of laptop you will see some panels under panels you will see two little wires connected to mother board that's the cmos battery unplug it and change it
Mar 30, 2009 | Toshiba Satellite 1805-S274 Notebook
TOSHIBA SATELLITE 1805-S274 BATTERY CHANGING
You cant really mess anything up there should be some kind of locking tabs on the bottom that are holding the battery. just release them and slide the battery out. If the Battery is mounted on the side look for the same thing. after that just put the new one in and you should be good to go.
Dec 03, 2008 | Toshiba Satellite 1805-S274 Notebook
Graphics Card Driver for Toshiba Satellite 1805-S274
Hello Ewuare,
Here is a link to Toshiba's Satellite Support Downloads page: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp. I couldn't locate the model number you posted above there, so you may want to double check it. You can find updated Graphics card drivers for your machine there.
Good luck.
Feb 28, 2008 | Toshiba Satellite 1805-S274 Notebook
Toshiba Satellite 1805-S274 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
