Question about Ovens
Westinghouse ceramic hotplate will not change to simmer
Hi Support Staff,
( Westinghouse Ceramic Hotplate Electrical Stove Model: PAJ806W: Ser.No.B2105684. Prod. Ref.2360245 )
Problem: One of the hotplates remains on 'High' even the knob/switch is turned down to 'simmer' . What may be the cause of this/ Does the Ceramic
hotplates have an element beneath the ceramic top and how does one change these. Thanks in advance.
Kindest regards
Jerry Ambrose
3 Suggested Answers
  • 3463 Answers
SOURCE: Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Posted on Mar 25, 2010
Testimonial: "Thank you so much for your reply. I am not sure how to get at the hotplates as they are under the ceramic top. Can you help with that?"
  • 1606 Answers
SOURCE: Question from electricain with long
I wonder if L1 and N are reversed, at least for this hot plate. The readings you get are consistent with a switched neutral and always-connected L1. This is not permitted in any electrical code I know.
If you get a constant 240 V at "terminal 1" referenced to "terminal 2", but no heat, and the resistance is consistent with a 1400 W heater when it's cold, I'd suspect a heater terminal or the element itself is opening up when it gets warm. If you have a means of measuring current such as a clamp-on induction ammeter, you may see an initial current up to 6 amps, then a quick drop-off to zero, random fluctuation, or cycling on and off. That would confirm my hypothesis.
Posted on Feb 07, 2011
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source.
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
I have no power to the oven or ceramic hotplate when the power switch is on
If the cooker has been working on lighter gauge wiring for a long time and then worked for a short while on thicker cable, it may be due to a failing or failed element. With the bigger cable, its just been taking longer to trip out.
Apr 19, 2015 | Ovens
Hotplate and oven temp
There are several possibilities. Make certain your fuse at the main electrical box is correct for a 220VAC line. You do not want to OVER POWER the range. If that is normal, check all cords for insulation and flexibility. Check thermostat controls on the burners and/or oven.
If parts are normal, the only thing you can do is manually set temps lower when using the oven. Glass tops generally stay hot for several minutes after they are turned off. That is Normal, for example, to avoid Glass from fracturing; temperature slowly declines. Lastly; if all is lost, call for a serviceman to check it out, as you do not want a house fire.
Jan 11, 2018 | Ovens
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
I have problems with my Hotplate!!!!! Name of the hotplate is just Induktion. The Hotplate is a Induktion and after a moment of heating it starts to blik and shots down with the Error: E R
From my previous mechanical engineering work, and have maintained a few of similar problems, but different maker. I found one one thqat it was not properly wired, check the owners manual and go over wire diagram. Secondly, is the kitchen on the other 2 I did the breqaker for that room was way over loaded, and sometimes it will shut your equiptment down b3efore the breaker goes off. This is because when the element reaches a certain tempature, or even rising in tempature the stove will kickback, almost like a car going into safemode, so it does not destroy the stove. I had to call an 3electrician, because3 I am not a certified elec.
Dec 26, 2012 | Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
Mar 25, 2010 | Ovens
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Aardvark Repairs
Nov 16, 2009 | Ovens
Ovens Logo
194 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
