Question about Motorola Mobility RAZR V3m Cellular Phone
Kepad errors? Upon turning phone on, pressing any key on the phone starts the recording message feature, and that's it. Now it says memeory full, and pressing any key or button does not due a damn thing....I can't dial, enter settings, etc. Any way to master reset the whole phone or is it toast?
    Brigadier General:
  • 7,752 Answers
Have the flexcable replaced and the mobile firmware reflash by taking it to any mobile service center close to you.
Posted on Feb 08, 2008
I have been trying to change our company greeting on the Panasonic KX-T7731 and can't figure out how. I have searched all the manuals. I also wasnt sure if I need to be on a certain phone/extension to
It's not part if the phone but deoends upon which switch (exchange) you are using and also if your using an external voicemail system or on the KXTES824 if you're using the built-in AA (Automatic Attendant)
Jan 15, 2015 | Panasonic KX-T7730 Corded Phone
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
I have a gigaset 4215 answering machine (but it says 4200 on the actual phone)...but no manual...and am trying to figure out how to record message for the answering machine so people know its mine...but...
You control the answering machine from the handset. First turn on the answering machine. Press Menu then use the up/down arrows keys to navigate to Ans Machine. Press OK then navigate to Answering M. Look for a check next to this to indicate it is on. Press OK to toggle the answering system on or off. Then press End or left arrow to return to the previous menu. If the machine's memory is full, it will switch off. Delete messages so that the unit will keep the answering machine feature on.
Next to record a new message follow the above steps to reach the Ans Machine menu and press OK. Scroll to Announcements and press OK. Scroll to Record Annc or Rec Annc Only (if no messages will be recorded). Press OK then bring the handset to your ear and listen for the notification of recording and then the tone. State your message clearly into the microphone of the handset. Press End to stop recording and listen to the unit play back your announcement. (It will stop automatically after 170 seconds or a 2 second pause in your speaking.) If an Annc Only message is available, the machine will play it when the memory is full. Otherwise, it will turn off.
To select your announcement (and recording type) follow the above steps to Announcements and press OK. Then scroll to Mode and press OK. Scroll to Annc or Annc Only (available if the Announcement only recording has been made) then press OK. Again OK toggles the announcement on or off; look for a check mark to indicate the announcement will be played. Press End to exit the menu.
Retrevo has the manual for the Gigaset 4215 here: http://www.retrevo.com/support/Siemens-4215-Telephones-manual/id/23319bh144/t/2/ . You will need to enter a code to download the file.
I hope this helps.
May 05, 2011 | Siemens Gigaset 4215 Cordless Phone
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
I'm trying to set up my voice mail and I am getting a message "mailbox locked". Is there a generic password I can enter that will work? Too, can you send me a step-by-step go-by to set up my mailbox?...
If you recieve the message "mailbox locked" then the password was incorrectlyentered too many times.
To reset your password press feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
As far as setting up your Mailbox, press your open mailbox key or press feature 981.
When prompted to enter your password enter the password of 0000.
The voice mail will make you change and confirm your password at this point. your password can be between 4 and 8 digits but cannot start with a 0.
after the password is changed the voice mail will make you record your name for the company directory. once the name recording is accepted, the mailbox will be at your main screen.
To record a greeting for your mail box,
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
Dec 22, 2009 | NorStar M7310 Corded Phone
I have a panasonic Cordless phone and can't remember how to remote access it?
Using the answering system
remotely
Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code (page 59).
LThe unit plays back new messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Note:
LYou can ignore the voice guidance and
control the unit using remote commands
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 3 minutes of recording time is
available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
Key Remote command
{1} Repeat message (during
playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{7} Recording a greeting
message
You can download the full manual at
http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
Please make sure to rate this solution. Thanks.
Jul 23, 2009 | Panasonic KX-TG5776S Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
