Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 136 chain brake handle spring.
What are the steps for installing the double loop spring in to the husqvarna 136 chain brake handle? The spring fits in the gray handle above handle bolt and grommets. I think I know where the spring goes but I can't figure out the final assembly.
    President:
  • 2,220 Answers
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Install side cover on 455 rancher with chain break
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Feb 10, 2014 | Husqvarna Garden
I have a Husqvarna 136 / 141 model chainsaw - it has been idle for several months. After starting and allowing to warm up for a minute or two and then attempting to use it - when applying full throtle the...
Has the chain stuck to the bar.? Chain oil has a tendancy to turn to a gluey state when say for some time. Is the chain brake fully releasing.?
Aug 29, 2011 | Husqvarna Garden
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Apr 15, 2011 | Husqvarna Garden
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Replacing bar on husqvarna 340 saw. Appears to be a spring attached to guard that will not allow the guard to slide off. Does spring have a certain amount of tension and how is it removed so guard will...
Sounds like the blade brake is engaged. You should be able to pull the blade brake handle, located on top of the saw, in front of the top handle, back towards the handle to disengage it. You can find replacement bars, chains & sprockets for your saw at Partsbuggy.com.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I tighten the chain for model 136?
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
\how do you take the clutch cover off a husqvarna 350. It seems to be connected to a spring attached to the clutch?
Your Anti kick back brake is engaged. pull the brake handle back to disengage it before you try to start the machine
Jun 18, 2010 | Husqvarna Chain Saw 20" Bar
Hi, I took off the clutch cover for my Husqvarna 136 saw and I can't get it to go back on. Any suggestions?
you need to disangage you chain brake band as it is engaged and wont go over the the clutch hub sprocket
Aug 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
1,560 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
