Question about Xerox WorkCentre XD125F All-In-One Laser Printer
J2 ERROR hi i have an xd125f and the screen is displaying an error J2, and its not allowing me to copie. can you please advice me on how to deal with this problem tks emily
    Problem Solver:
  • 11 Answers
Replace the Drum Cartridge.
Posted on Aug 02, 2009
Getting J2 on the screen copier won't work
That means the drum cartridge has reached the end of its life.
You can replace the drum unit or the chip on back.
You can google a business called "the parts drop."
They should have both.
Jan 19, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
J2 Error on XD125F
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Sep 17, 2008 | Xerox WorkCentre XD130DF Laser Printer
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
Xerox Workcenter XD125F
Either the feed rollers are dirty or in need of replacing.
Try this first. Take a piece of regular copy paper and on the front in the middle put a small amount or rubbing alcohol on it. IN the middle about 2 inches wide and 2 inched deep. Dampen the paper, do not drench it, and do NOT use a soapy cleaner since the alcohol will not shred the paper. Place that sheet into the feeder and hold the back of the paper, cause it to jam. What that will do is spin the rollers on the alcohol and paper and clean the roller surface. Keep doing that until the paper comes out clean, then allow a couple of minutes for the rollers to dry before running the machine.
If that still doesn't help the rollers will need replaced. Look up, on Google , The Parts Drop, they should show up first. Call them and ask for Britt. Nope its not me and I don't work there, Just deal with them. Excellent people there.
Good luck and let me know please.
Aug 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
"Format Error" after format with windows explorer (XP)
Hello, please check this link: http://support.sony-europe.com/DNA/WM/NW... If you need more info please advice. Arpi
Feb 01, 2007 | Sony NW-E405 MP3 Player
Printer problen
Low Fuser Temperature. Probably a blown heat lamp try reseting the H code Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code comes back. Tim
Jan 28, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
250 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
