Question about Ariston Technologies Dishwashers
Ariston LSI 41 dish washer had intermitant problem of green light not coming on when main power switch turned on and machine not working, the circuit had beed repair before. I played around and got the machine to go through a full circle once then would not go again. So I have put a new circuit board with switch etc. still the switch panel light dose not come on, i found bad connection in connector which comes from small plug on circuit board, (two red wires )I have checked for power to board. When I lift the mirco switch which is on the float in the bottom of the machine tray the green ligh flashes and a pump comes on for a while. Can you help with a wiring diagram. I am a motor mechanic and have a meter for testing etc. Thanks John
SOURCE: ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour called around and he popped the right wire in the right place and we were in business. Not sure what he did and he is not sure either. Thankyou Wal.
Posted on Nov 16, 2008
SOURCE: Light blinks 7 times on a du1050 whirlpool dish washer
I am having this problem now. I have replaced the circuit board, without success. There are many things that could be the cause, but I will be checking the door latch switches first. Also, if the main wash pump becomes clogged this could also cause the error code.
Posted on Oct 09, 2009
  • 161 Answers
SOURCE: found 2 red wires on bottom with small plug? end
it could be extra wiring used on a different model w/in the kitchenaide line of d/w...they sometimes use the same wiring harness for many different models
Posted on Mar 06, 2010
  • 901 Answers
SOURCE: my Ariston LSI 45/50 makes a loud bang during the cycle
hope your dishes are firm in it's seating.
Posted on May 03, 2010
  • 414 Answers
SOURCE: bosch she6ap05 dishwasher not heating
If the unit is not heating, it may give an error message (usually e09) the chances are that it is the heat pump (part number 669135). The circulating motor and heater are combined in this one unit. It is also possible that the power board (situated behind the right side panel, bottom right) is at fault, this needs to be replaced by a qualified engineer as the software is booted by a coding program through a specific computer program. The heat pump will be your first check tho, the heating side is the contacts under the larger connection block and should read approx 20-30 ohms. Hope his helps, if you require more info please add a comment.
Posted on Mar 03, 2013
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Why my washing machine unable to switch on?
If there are no lights, check the fuse in the plug.
If the machine comes on but the drum does not move, the motor control circuit board probably has a burnt connection or bad joint. This may also be the cause of the fuse blowing.
Jun 05, 2014 | Ariston Technologies Ariston AWD12 Front...
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
All lights flash - machine does not work
the machine is unstable as in you have to big of a load in or uneven load it happened to me when i put really heavy bath mats.
Jul 10, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Dial continuously turning
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Ariston Technologies Ariston AWD12 Front...
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
Dishwashers Logo
402 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
