posted by chuckmoney on Nov 06, 2007
Fridge warm had frosted evap. short LINE & DEFR. on main board (adaptive and control in one). No defrost initiated. tech <GE now Mabe> manual says replace board. check out evap. thermist ohm out in speck temp chart.
Return w/part four days later. Know compressor running defrost heater on at same time?
Replace board <redesigned separate ground+remove groung from relay as tech sheet says> Run 48 hrs OK 72 hrs later fridge warm, freezer cold and making ice???
Air damp. suspect but @ a loss if not the problem. Tech manual didn't quite make the translatin from english to english.
Have you had the same problem? Wow I am beginning to miss the regular mechanical defrost timers and bi-metal therms <evap>
Thanks in advance Chuck
Suggest a new solution for this problem
Post a New problem for GE Energy Star PDS22SIS Stainless
Email this problem
Email this problem
Can you Help with these Refrigerators problems?
GE Energy Star PDS22SIS Stainless Steel...
fridge running hot.
fridge running hot.
The LED shows the fridge temp... Answer This...
led display works sometimes and...
please help. LED display works... Answer This...
GE Profile freezer bottom
Hello i am experiencing... Answer This...
Freezer temp gone whacky all of...
adjust the freezer to 0 degrees... Answer This...
ge bottom freezer ice maker
ice maker dumps ice cubes on... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
Find Parts
