Question about Sony Handycam DCR-HC90 Mini DV Digital Camcorder
I have a 4 year old sony handycam, model dcr-hc90. quit working on battery power, but is fine on ac power. baterries check out fine. took it into best buy geek squad. was told that a component board, part vc-380 pcb needed to be replaced. they wanted more than i paid for the camcorder to repair it. is this something i could attemt myself?
  • scott Jun 28, 2009
    So are you saying that this can be repaired without replacing the component board as I was told by geek squad?
    Genius:
  • 1,341 Answers
I would be careful if I was you.To replace a pcb you will need to have the right equipment and expertise.You will probably need to have a soldering iron,a meter etc..and a slight mistake while soldering could be disastrous to this camera.So be careful,if I were you I would try to get a sort of mobile ac power,like a 10w or something would do enough for this camera.There is no point to spend money fixing it as it is costing too much.I hope this helps.
Posted on Jun 28, 2009
    Brigadier General:
  • 3,917 Answers
This would be highly technical. Not sure of your expertise but since its the main part of a handycam would suggest to either go for a new handycm or get an expert to do it for you.
Remove ALL electrolytic caps. Very carefully inspect underneath caps for trace damage. If there is, install a jumper (esp. under 47uf caps. This will fix your problem. Carefull with this camera, I will not hardly fix them anymore due to main pcb and sensor pcb damage from electrolite. Replace all grip caps and evf will work.
Thanks for contacting Fixya
Posted on Jun 27, 2009
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
The lense sutter of Sony DCR-HC90 MiniDV is blocked by sand (I was filming on the beach) and does not open when camera is on. Is there is a way to clean it?
The lens cover mechanism in these cameras is susceptible to debris and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 13, 2010 | Sony Handycam DCR-HC90 Mini DV Digital...
Have trouble with the cassette compartment on the Sony Handycam dcr-hc90. It is stuck in the open position. Everywhere that I have tried to see about getting it fixed is asking an outrageous price. Any...
This is usually caused by a defective tape mechanism position sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 01, 2010 | Sony Handycam DCR-HC90 Mini DV Digital...
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony handycam just quit.. won't charge or work it just died no notice given.
Does it power up if connected with AC Power Adapter?
Have you tried extra AC Power Adapter or tested with another Sony Camera?
Let me know to guide you further.
Nov 08, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
I link in DCR-HC 54 models
try to go here and download the driver or just look for your model and download on that link. install it to your pc.
http://www.sony-asia.com/support/download/1656/product/dcr-hc39e?site=hp_en_AP_i
try also here
http://download.css.ap.sony.com/consumer/IM/2584907131.pdf?p=1
CHARCOIS
Aug 24, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
AC Power Adapter
Hi here is link where you can buy this ac adapter/charger for DCR-DVD108
http://azsurplus.com/index.php?main_page=product_info&cPath=1_85&products_id=1910
it is also works with more models as mentioned bellow
Compatible Part Numbers: AC-L20A, AC-L25A, AC-L25B, AC-L200
Input: AC 100V-240V 50/60Hz
Output: 8.4V 1.5A
Dimension Approximate: (48mm x 29mm x
To Use With :
CCD-TRV138
CCD-TRV338
DCR-DVD103
DCR-DVD105
DCR-DVD108
DCRDVD202E
DCR-DVD203
DCRDVD203E
DCR-DVD205
DCR-DVD305
DCR-DVD403
DCRDVD403E
DCR-DVD405
DCR-DVD505
DCR-DVD508
DCR-DVD7
DCR-DVD92
DCR-DVD92E
DCR-HC1000
DCR-HC1000E
DCR-HC16E
DCR-HC17E
DCR-HC18E
DCR-HC19E
DCR-HC20
DCR-HC20E
DCR-HC21
DCR-HC22E
DCR-HC26
DCR-HC28
DCR-HC30
DCR-HC30E
DCR-HC32
DCR-HC32E
DCR-HC36
DCR-HC39E
DCR-HC40
DCR-HC40E
DCR-HC42
DCR-HC42E
DCR-HC46
DCR-HC65
DCR-HC85
DCR-HC85E
DCR-HC90
DCR-HC90E
DCR-HC96
DCR-HE20E
DCR-HE22E
DCR-HE30E
DCR-HE32E
DCR-HE40E
DCR-HE65E
DCR-HE85E
DCR-IP1
DCR-IP1E
DCR-IP210E
DCR-IP220
DCR-IP220E
DCR-IP45E
DCR-IP5
DCR-IP55
DCR-IP55E
DCR-IP5E
DCR-IP7BT
DCR-IP7E
DCR-PC1000
DCR-PC106E
DCR-PC107E
DCR-PC108E
DCR-PC109
DCR-PC109E
DCR-PC350
DCR-PC350E
DCR-PC53E
DCR-PC55/B
DCR-PC55/R
DCR-PC55/S
DCR-PC55/W
DCR-PC55E
DCR-SR100
DCR-SR200
DCR-SR300
DCR-SR40
DCR-SR60
DCR-SR80
DCR-SR82
DCR-TRV280
DCR-TRV480
HDR-CX7
HDR-HC3
HDR-HC5
HDR-HC7
HDR-SR7
HDR-UX5
Jul 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Logo
133 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
