Question about John Deere Garden
We have a 2004 JD X495 tractor. I was cutting grass and the pto shut off. I was mowing foward. The pto will not power on.
  • 272 Answers
SOURCE: JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
Posted on May 10, 2009
  • 246 Answers
SOURCE: when I mow with my 42
Hello:
This is Usually Caused by Worn Blades or a Bad Mandral/Blade Spindle Bearing.
Remove the Deck from Under the Mower.
Remove the Deck Belt.
Check the Mandrals/Blade Spindles for Bad Bearings. Do the Sound Rough when you Spin the Pulleys by Hand? Can you Move the Mandralls/Blade Spindles from Side to Side? If Yes, then the Bearing s Require Replacing.
Look At the Tips of the Cutting Edge of the Blades. You will Se the Tips are Rounded and Not Square. This Condition will cause the Strip in the Center of the Deck.
I have Just Joined this Site. If you Send me the Model Numbers Off the Unit, I can Assist you Better.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
  • 760 Answers
SOURCE: while cutting grass the pto
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Posted on Aug 18, 2010
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
How to fix JD x320 grass height level and blade engagement
Check if lever come unhooked or a stick or something blocking it.
Oct 21, 2014 | Garden
PTO stopped working. What can cause this to happen?
bad safty switch or bad switch or pto burned out pto cost 200.00 switch engagement 15.00 or bad safty switch 15.00 pto dont go out that often not unless your mowing heavy grass
Aug 29, 2014 | Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Blades disengage after mowing for a while on John deere x495
This could be a couple of things. Your pto clutch could be going bad. Or, if you loose charge from battery your pto will shut off as well. I would check volts across battery terminals, then start unit and raise rpms and note the change if any. If there is no change in rpms from stopped,idle, to high rpms you have a charging issue that would cause this problem. If charging system checks out your problem probably lies in pto clutch. Hope this helps,good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 10, 2013 | Garden
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Tractor want move
safety on the seat if the blades were still lowered it will shut down the motor. have to disengage the pto.
Jul 19, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine cutting off after engaging the pto (mower deck) JD 317
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
183 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
