Question about Schwinn Sport Cruiser Women's Cruiser Bike
How to adjust or remove kickstand
The kickstand will not completely return to the upright position if moved to high it moves past frame bar it is a round insert with a triangular portion on the other side and the circular tube it goes into is welded to the frame. there is a small round dentent knobby thing that sticks out. can I buy a whole new setup or remove and and o adjust this one.
Thanks
Janome mc5200 sewing machine E3 code need to fix it myself. Cannot find it in my instruction book
Hello Dear Jeff Moore!
greeting
FYI......
Needle bar is out of position. Press OK to move the needle bar to switching position. (Needle bar change over phase.) 3. Remove the stationary cover then turn the hand wheel to 270°. Using a 2.5mm hex driver, turn the silver gear on the needle-change step motor to move the head from needle bar #1 to #4 then back to #1 to check for any binds. If there is a bind, adjust 'head play' as shown in the service manual. 4. Check and adjust 'moving head stop position' and 'needle stop position' as shown in the service manual.
May 23, 2018 | Janome Sewing Machines
Toyota Sienna third row seat won't lock into place in the upright position. Already cleared around locking bar and moved rug, nothing is getting in the way of the locking bar.
maybe the catch has move and needs adjusting .....or there is movement in the catch that means it cannot retain lock.
This is a situation where you can only empirically find out what the issue is.
good luck
Jul 06, 2015 | Toyota Sienna Cars & Trucks
Kickstand fell off on a road king and not sure how it goes back
To replace the 2011 Touring jiffy stand leg FIRST support the motorcycle with a suitable lifting device so it securely upright and level and the jiffy stand is able to move through its full range of travel, move the jiffy stand to the full forward or down position, remove the hex bolt,the lockwasher, the flat washer and the leg stop, swing the jiffy stand forward beyond the normal down position and remove the end of the spring from the jiffy stand, remove the leg from the bracket, remove the other end of the spring from the frame weldment, inspect all of the parts for wear/damage and replace if and as necessary. TO install the leg FIRST apply SILVER GRADE ANTI-SEIZE compound to the area of the leg that rotates within the bracket, verify that the end of the spring enters the hole from the front of the leg weldment because if the end of the spring enters the hole from the rear of the weldment the spring coil will rub on the leg when in use, install the end of the spring into the hole in the frame weldment, insert the leg up through the bracket, swing the jiffy stand forward beyond the normal down position and install other end of the spring into the hole in the leg weldment. Be careful to install the leg correctly because if it is installed incorrectly excessive wear can occur which will allow the vehicle to fall when rested on the jiffy stand. THEN holding the leg at the normal forward (down) position, install the stop over the threaded end with the stamped side down, verify that the longer side of the stop faces the rear of the motorcycle, install the flat washer, the lockwasher and the hex screw and tighten it to 15-20 ft-lbs (20.3-27.1 Nm), extend and retract the jiffy stand several times to verify proper operation, freely swinging to both the fully extended and the fully retracted positions, move the jiffy stand to the full forward (down) position and remove the lifting device and let the motorcycle rest on the jiffy stand, verify that the rubber stop is installed in the hole of the jiffy stand weldment to prevent damage to the painted finish.
To remove the 2011 touring jiffy stand bracket FIRST lift and support the motorcycle in a fully upright position off of the jiffy stand, remove the left rider footboard and support brackets, remove the jiffy stand leg, remove the two fasteners and the lockwashers to release the jiffy stand bracket from the frame weldment.
To Install the 2011 touring jiffy stand bracket FIRST install the two fasteners and lockwashers to secure the front of the bracket to the frame weldment, temporarily install the footboard rear fastener to align the rear of the jiffy stand bracket but do not tighten it, tighten the front fasteners to 36-42 ft-lbs (48.8-57.0 Nm), install the footrest and install the jiffy stand leg.
May 08, 2014 | 2011 Harley Davidson FLHR Road King
Sole F85 E2 error code. Have adjusted the sensor several times along with running recalibration. All grounds and board connections seem to be secure. What else should I check. Unit worked until we...
If it was moved . Most likely the cable was damaged where the right upright bar slides into the frame. You will need to take the console off and remove the right upright , too access the cable. Unless you live in NC you could call, wilsons triad fitness 336-313-6253
Dec 08, 2017 | Sole Fitness Sole F85 Treadmill
I cant get my c2050 out of the doorway.ive tryed getting it trhue the dooeway no angle will work. i cant find anything to detach to take it apart. any suggestions?
A) HOW TO LOWER THE TREADMILL FOR USE
1. Refer to drawing 2 above. Hold the upper end of the treadmill with your right hand as shown. Using your left
hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock
knob. Note: You may need to push the handrail to the side slightly.
2. Refer to drawing 1 above. Hold the treadmill firmly with both hands, and lower the treadmill
Watch thsi video:
http://www.youtube.com/watch?v=kDNegYEnrSc
Before folding the treadmill, adjust the incline to the
lowest position. If this is not done, the treadmill may be permanently
damaged. Remove the key and unplug the power
cord.
1. Hold the treadmill with your hands in the locations shown
at the right.
Raise the treadmill about halfway
to the vertical position.
2. Move your right hand to the position shown and hold the
Sep 25, 2011 | Nordic Track NordicTrack Treadmill, A2550
How do I folds my baby einstein musical motion activity jumper
Thank you for your question. I am happy to help you. Here are the steps you need to take for folding your jumper. I have included a link to your jumper instructions and attached a copy of page #17 which demonstrates how to complete the steps below.
  1. Move the 4 blue balls that attach the seat to the upright bars up to the fabric wrapped part of the uprights.
  2. Pull one end of the upright arch frame tube upward while pressing its release button on the hub (the blue part that connects the upright arch frames to the base frame). Pull frame until it is removed from the hub.
  3. Repeat step #2 for the opposite side of that frame and again for the other frame until all 4 hub connections have been removed.
  4. Now the arch frames will be laying colapsed on top of the base frame and ready for storage.
http://www.kidsii.com/descriptions/productspecs/30917_1_3WW_PKG061909r3_IS.pdf kellena_1.gif
I sincerely hope this helps you. Good Luck with your jumper and your sweet baby!
Jan 20, 2011 | Kids II Baby Einstein Musical Motion...
Why does bike size is important?
It is clear that wearing a shirt two sizes too small would be uncomfortable, and wearing a shirt two sizes too large wouldn't be good either. In the same way, riding a wrong size bike will fit badly and make you uncomfortable, too. There are two main problems, one obvious and one a little more subtle.
The first big problem with a bike that doesn't fit is saddle height. You need the saddle to be just high enough to give your legs the right extension when you pedal. Too low and your legs stay bent too much all the way around; this doesn't use your leg muscles well and you wear out quickly. Too high and you rock back and forth on the saddle as you pedal, very uncomfortable. Either extreme (too high or too low) can also be very hard on your knees.
Saddle height is adjustable, of course, and if the bike frame is at least close to the right size, you'll be able to adjust the saddle to the proper height. If the frame is a lot too small, you can usually overcome this problem by buying a longer seatpost to move the saddle back up to where you want it. (But that causes other problems we'll talk about soon.) If the frame is much too large, you won't be able to drop the seat far enough to be usable, and there is no practical way around that problem.
The saddle on a bike can be adjusted up and down several inches, even as much as a foot if you consider replacing the original seatpost with a longer one. But the handlebars can't be moved nearly as far as saddles can. Most handlebars can be adjusted up and down or forward and back only two inches or so, and even this small change is often a complicated operation of replacing parts, not just loosening a few bolts.
This can lead to all sorts of problems. If the handlebar is too far away from the saddle, you have to bend down further and reach far out to grab the bars. This puts more weight on your back, arms and hands, which is uncomfortable. Having the handlebar too close to the saddle is less of a problem, but in extreme cases it can cause your knees to bump the handlebars when you are standing up to climb a hill. Having the handlebar a lot lower than the saddle is similar to having it too far away-you have to bend far over and reach further to grab the bars, an uncomfortable position. Having the handlebars high up is not a big problem, except that sitting upright slows you down. Your legs aren't as strong when you are sitting up, and that position causes more wind resistance when riding fast or into a wind.
Bike size has a big effect on handlebar position. If the frame is too small, you'll have to push the seat up high to fit your legs. You won't be able to move the handlebar up as much, so it will be a long reach back down to grab the bars, and your back will be quite bent over. If on the other hand the frame is too large, the bars will be up high but might be too far forward (since the frame gets longer as well as taller).
Dec 21, 2010 | Cycling
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I can see the height adjuster under my Bissell pet hair eraser vacuum, but it doesn't adjust. The parts don't look like they're touching. It's been iffy since I took it out of the box. Now it doesn't...
http://uk.bissell.com/images/UserGuides/3920E_508.pdf
This is the pdf manual. If you look at page 12 you'll see that the bottom of the machine has been pictured. Between the middle wheels near the brush (where arrows 4 and 2 are) you'll find that the adjuster bar has a sprung mechanism. Now this is easy if you have time! If you take off the or just inspect the bar, check to see that nothing is clogged behind it. If it looks fine, check with your other hand by moving the rotary dial a couple of times and your other hand pressed down on the central bar between the wheels - if you can feel that the bar is moving whilst you turn the rotary dial then it should be working. Sometimes the spring that connects the dial to the bar can loosen and this may well have been the case. If you can unscrew the assembly do it gently as it will pop up to see if the spring has been put in place and then carefully put everything back together.
Some uprights don't allow the height adjuster to adjust whilst in the upright position though but if it doesn't adjust at all then the spring has definately moved.
Jul 26, 2008 | Bissell Vacuums
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Schwinn Sport Cruiser Women's Cruiser Bike Logo
966 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
