Question about KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
The black rubber that blender sits on is breaking off.
See above
  • 145 Answers
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
. there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
you can then remove the base.
Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
Jan 21, 2017 | Breville Blenders
Need a blade assembly for Black & Decker Blender Model No. BL2010BGC
Fixya does not sell replacement blade assemblies. Check with a local appliance parts supplier.
Oct 26, 2016 | Blenders
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
The black rubber part that the glass sits on had broken right of the housing. Can a part be ordered or do i need to buy a new blender
It is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here:http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx The part is available on Amazon as well as many other sites.
Jan 12, 2011 | KitchenAid KSB3 Classic Work Top Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
A blender parts
You can most likely find all kind of blender parts at www.thegourmetdepotco.com. I just bought a Krups blender rubber drive gear from that online store. It's the best lowest price, compared it to Amazon.com too. Try it.
Nov 20, 2008 | Blenders
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
622 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
