Connecting a subwoofer to a KR-V6080
The receiver only has connections for two sets of rear speakers, a set of front speakers, and a center speaker. Can I connect a powered subwoofer? The speaker is a Elements Electronics ESW12.
  • 30 Answers
As long as you change out the connectors, you can run it anywhere you wish. I suggest a rear channel.
Posted on Jun 27, 2009
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
How to set up surround sound
Not sure what you are looking for
But if 5 speaker setup have your front left and right speakers on the appropriate side of the television, your center speaker in the middle of the tv, Either mounted on the wall or underneath or on the shelf, try to have the center speaker set back from the front speakers. Subwoofer usually I mount behind the entertainment center. Your rear right and left speakers optimum position is behind you on the left and right.
If its a 7 speaker setup everything is the same except side right and left speakers go in the middle somewhere between the right and left front and rear speakers
I will make a example the the cursors [] Speaker *TV
LF[] CT and TV*[] RF[] []Subwoofer behind tv
SL[] []SR
LR[] RR[]
Hopefully that helps
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 15, 2013 | Audio Players & Recorders
Speakers front 1 and front 2/sub room section work fine, but the center and rear sections won't work.
Is this an amplified system by a amplifier? Check the connections at the back of the receiver/radio. Also check the settings of your radio, the center & rear channels might be turned off.
Apr 09, 2011 | Car Audio & Video
I have no idea how to connect these speakers all I have is the wires for the 5 speakers and a power cord for the sub any help please?
You have not mentioned -- connect it to what ???. Assuming that its an AV receiver. Start by connecting the front three speakers to the the amplifiers speaker sockets labeled Left front / Center / Right Front. These are connected using three short wires. Then connect the two surround speakers using the pair of long speaker cables. You will need a RCA to RCA cable to connect the subwoofer to the Receivers subwoofer preamp out.The subwoofer also requires an A/C wall socket to power it.
Mar 08, 2011 | Cerwin Vega AVS-5.1 System
Yesterday, I connected two speakers to my Kenwood KR-V7070 Receiver and it worked fine but today I can't hear anything coming out of the speakers. I may have pressed a wrong button on the remote. Also,...
Tell us some details about the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V7070-Receivers-manual/id/479bh947/t/2/
Familiarize yourself with the controls. Understand every indicator on the front. There may be a clue there. Turn the volume to a medium or low level before changing any settings or you may be in for a BIG (and costly) surprise when you find the one that was in the wrong position.
Let
Mar 02, 2011 | Kenwood Audio Players & Recorders
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
499 people viewed this question
 Grubhead
Grubhead
