Question about ASUS A7N8X-X Motherboard
My CD and DVD drives have disappeared
All of a sudden my CD and DVD drives have disappeared from my computer. They are no longer listed as drives. I have checked that they are plugged in correctly. Please help.
  • Les Morrison
    Les Morrison May 11, 2010
    What OS are you using? IF its a Windows flavor you can run a slew of programs to to discover the issue my bet, If the hardware is ok, would be a registry error.
    Novelist:
    Champion:
  • 256 Answers
There is not much that can go wrong with the drives. My suggestion is that probably you have something wrong with the power supply. Power supplies are multivoltage and if one should not work, then you could lose it from the list of installed tiems. How is the Hard Disk doing? Do you get good performance, memory and communications? After the voltages and connections on the power supply, please, even though they are re-chargeable and there is no reason to need replacement, check and verufy that the Mother Board Clock Battery has its specified voltage, which is 3VDC. I suggest you go to a Hardware store and buy a cheap (but good) DVOM (Digital Volt Ohm Milliammeter). You will use it to check all the voltages, as we said, plus you will have it handy to check and/or verify other voltages, connections and other tests. The last time I bought a very good one for US $ 3.95 (I believe now they go for about US $ 9.99. Question: in case you need more help from us, do you have separate CD and DVD drives? Because once you have the DVD you don't need the CD. Please, if you need any more help from us, give us the following Information: (1) The manufactuer's Name and Trade Name of the computer; (2) The Model Name and Number; (3) The identification number of the Mother Board. If you have trouble finding it, we will gladly help you. It is very important for our diagnosis. (4) A detailed accurate report of how the problem came into being, before the failure, during the failure and after it. WE need all the details you can think off. Something that you consider unimportant, may be the key to our solution. We thank you for considering our service. CONSTANTIN (arzconst)
Posted on Jun 27, 2009
My dvd/cd driver has disappeared
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
May 04, 2012 | Computers & Internet
My DVD WAS Playing fine then i heard noise sound like comming from the door of the player.Then it stop playing all of a sudden and now the cumputer can't fine the E drive it was using. there is no longer...
The motor that spins the disk has failed - the cd unit is dead and the unit is no longer listed in Computer because of that. Just replace it with a new one - it's a very cheap part, less than $30.
Apr 01, 2011 | Computers & Internet
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
My cd/dvd drive on my Fujitsu Siemens laptop doesnt work
Right click on my computer icon then click on property then ->hardware ->device manager
then check there is any cd/ dvd drive showing in list.
If you can see your cd /dvd driver then uninstall it.
then restart computer.
But if you cant seen then you need to refix your cd dvd rom.
For that pull your cd drive from laptop but make sure there is 1 lock system near rom just press that lock and pull drive then refix it.
Aug 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Jun 15, 2009 | HP Pavilion DV2740SE Laptop
My Dvd rom has disappeared. how do i get it back
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
CANNOT FIND CD/DVD DRIVE ON ACER ASPIRE 5100
Is the hardware listed in the BIOS? When the computer first starts up hit a key to get in the BIOS (Esc, F2 or F10 are most likely). If it's not listed in the BIOS then it's likely a hardware problem. Try checking the connections to make sure it's plugged in and getting power.
If it is listed in the BIOS, it's likely a problem within Windows. Check Acer's website for known issues with the cd-rom.
Nov 25, 2008 | Acer Aspire 5100 Notebook
DVD drive recognition
remove your ide cables and power cable and also jumper setting in your dvd drive check it
Oct 01, 2008 | Microsoft Windows XP Home Edition
Cd drive
try to unplugged all the connection through the CD/DVD drive. and plug it again.. maybe this would work. sometimes this happin for faulty connection for ide cable and supply cable.
Sep 02, 2008 | Computers & Internet
Loosing cd/dvd completely from device manager
check your dvd in bios. is it recognised in bios ?
also try to push your dvd, dvd connection to motherboard might be loose.
Jul 31, 2008 | Acer Aspire 9300 Notebook
ASUS A7N8X-X Motherboard Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
